Home > Technical (L322) > Aircon not blowing cold air |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
As per title, I'm no longer getting cold air from the A/C. Where should I start looking? Or Is it a just a case of re-gassing it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
23rd May 2012 5:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35246 |
try a re-gas and then consider the air con radiator might be leaking...its right in front of the 'normal' rad and gets easily damaged by stones of the road... ... - .- -.
23rd May 2012 7:26am |
Don't go to Kwikfit, they haven't a clue. Best find someone who knows what they are doing. I did a 50 mile round trip last week to have mine re-gassed |
23rd May 2012 7:28am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I used kwikfit, service/attitude was poor. Aircon worked for a few days then no cold air again. I must have a leak.
23rd May 2012 7:33am |
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 |
Hopefully regassing should fix it. I got mine done last year, and it's working fine. |
23rd May 2012 7:36am |
A place in Carluke, 3 cars for £80 |
23rd May 2012 7:53am |
Hope you have better luck than I did, in mine the compressor packed up and spewed crap through the entire system. Have almost everything replaced ;( Take it to a good A/C place to make sure there are no other issues. They can also add some "tracer" to the fluid to find leaks. MY 2010 5.0 SC Galway green and sand interior!!
23rd May 2012 8:24am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Hey noddy, given we have the same age car.....
23rd May 2012 9:22am |
The air-con should be kept running all the time. Modern units do not consume much energy unlike the old clutch type. |
23rd May 2012 9:27am |
Amen to both of these statements. Kwikshit / Jiffypube like places should not be allowed to touch an AC, IMO. Regassing alone is only a real solution in about 1-2% of all AC probs. If all other AC components are ok then the gas still went somewhere. The new gas will go there too. If you don't fix the problem, you will have done nothing but waste money and harmed the environment. The gas carries oil with it when it rushes through the system to keep you cool (this is why ACs should be run even in winter - the o-rings and seals dry out without oil and the system leaks. Not to mention the positive effects of dehumidifying the interior of the vehicle. Where is Dan now?). This oil comes out at leaks too and often an oily smudge is a good indicator of a problem. As Stan said, the condenser (AC radiator) is prone to leaking as the aluminum corrodes and holes open. Hard to check quickly and expensive to replace. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
23rd May 2012 10:20am |
