Home > Maintenance & Mods (L322) > Smokey Exhaust
Page 1 of 3 123>
Elena
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Smokey Exhaust
Hi all
I did not use my car for one week but when I used it yesterday the exhausts both smoked terribly for 2 miles; I stopped the car and turned the engine off for 10 minutes. I then restarted the engine and drove the car with no smoke at all.
Can I expect this when ever the car has't been used for a few days. The car is a 2006 Vogue 3.0 TD6.
Regards
Elena
Post #122595 18th May 2012 8:10pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
smoke on the td6 engine is generally caused by the engine breather assembley not being changed.
Post #123155 23rd May 2012 12:05am
Elena
Hi Arron
Is that something I can do or does it have to go to a garage, thanks for your reply
Regards
Elena
Post #123161 23rd May 2012 6:40am
arron
its simple enough to replace, take the engine cover off and look towards the rear of the engine. you need to undo the injector loom to get to it. once you bought your new breather it will be much easier to spot on the engine, its held on the engine by allan headed bolts. heres a link to one on ebay
http://www.ebay.co.uk/itm/Freelander-TD4-a...415667545a
but to be honest your best getting one from a dealer.
Post #123357 23rd May 2012 11:10pm
ahebron
New Zealand
Hi Elena.
If Arrons suggestion does not work for you have a look inside the inlet manifold by removing the egr valve. Mine didn't smoke when I bought it but about a month later was leaving big black clouds everytime I accelerated. It turned out to be a heavily sooted inlet manifold.
Adrian VW Amarok 2014 Highline auto
Post #123387 24th May 2012 8:54am
i to recommend removing the egr valve..better mpg and no smoke.. ... - .- -.
Post #123399 24th May 2012 9:41am
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
+1 Thumbs Up
Post #123432 24th May 2012 11:47am
arron
dito on the egr too, i dont want to feel left out. lol Laughing
Post #123550 24th May 2012 10:50pm
Elena
Isn't the EGR thing needed, if not could you talk me through how to remove it.
Cheers
Elena
Post #125839 12th Jun 2012 4:55pm
all in the wiki elena.. ... - .- -.
Post #125841 12th Jun 2012 4:58pm
Elena
Hi Stan
Found it, this is the most expensive car I have owned and the one I have taken apart the most. I am learning a lot from this forum, cheers everyone
Post #125894 12th Jun 2012 8:37pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
If you struggle im only up the road and have done the breather and egr a few times just drop me a pm if u get stuck onto no6 Range Rover
Everyone needs a hobby
Post #125945 13th Jun 2012 10:03am
Elena
Hi, I probably should have said that the smoke is blue in colour
Post #126952 20th Jun 2012 8:13am
check your oil level cos i think you might be burning it through worn piston rings or valves.. ... - .- -.
Post #126954 20th Jun 2012 8:18am
Not a fan of the devils fuel but blue smoke could be the turbo oil seals. Better than worn pistonrings and valves but still. OT the best. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #126960 20th Jun 2012 9:15am
Page 1 of 3 123>
