Home > Technical (L322) > Door lock broke, cant open door |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
these might help,
17th May 2012 7:29am |
Stuart's the man Member Since: 16 May 2012 Location: Glasgow Posts: 94 |
Thanks for that,3rd one down helped. Managed to get panel off enough without any damage, then smashed door lock off.new lock fitted and working. The way I done it was undo 4 screws holding panel on, remove B post trim along with front door seal,remove black window trim from door panel and then a gentle lever to remove it from top clips. You are then in to the lock mechanism, all in an hours work and £81 for new lock. I took pictures of job in case anyone needs help
18th May 2012 8:29pm |
you're welcome stuart, glad its sorted.. ... - .- -.
18th May 2012 8:40pm |
