Home > Technical (L322) > Rough idle, revs drop, occasional stall, hot or cold |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
are we talking the breather hoses at the back of the engine, they should be firm and not soft, i think you have an air leak, check the breathers and the vac pipes, have a good listen for any hissing.do you get any hissing when you take the petrol cap off. V8 facelift Range Rover Autobiography 22" wheels.
13th May 2012 11:22pm |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
Does it do it on both Petrol and LPG? 5.0 supercharged autobiography
14th May 2012 5:42am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1391 |
Air flow meter.
14th May 2012 10:18am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Have you had the LPG serviced recently? I have this but not as bad. The LPG doesn't have as much bang and if it's tunning has slipped this can be caused. Mine does it when the AC compressor clutch is engaged. On petrol the ECU preempts this and over fuels to stop the dip in RPM on gas the dip is visible but hot as as bad as you have. Try on petrol with and without AC them again on gas with and without AC. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
14th May 2012 11:22am |
See, I'm not so convinced that this happens so much with modern LPG installs. The sequential stuff ( as I understand it ) looks at the injector pulse timing of the petrol injectors, and then it creates an LPG injector pulse based on it. It'll may trim it slightly based on the O2 readings. Once that ratio is set between the petrol injector pulse and the LPG injector pulse ... what can go out of sync? LPG follows the petrol. The petrol ECU runs completely unaware of whether its the petrol or lpg injectors throwing the fuel in. Any real fuel trimming gets done by the petrol ECU ... if it thinks the system is running rich, it'll back down the petrol injections till it reaches the correct air/fuel ratio .. and so the LPG will back down too. My point is that bad running as described is still principly controlled by the petrol ECU, what it reads from sensors and the calculations it makes to create the petrol injector timing. For the sake of £20 to get an ODB2 reader, it really is worth it to find out what the engine is seeing. My money is still on air flow meter V8 or else ... |
14th May 2012 2:37pm |
user58101 Member Since: 13 May 2012 Location: London Posts: 11 |
Thanks all.
14th May 2012 3:32pm |
I don't know the full ins and outs of LPG software but I'm not agreeing with this 100% (but could be very wrong). When I've had issues Andy (LPG tech) has plugged the laptop in and I've seen the graphs produced while the LPG has been in a learning cycle. Now he can adjust these to get the two graphs to match using what I can only assume as a trim type setting. Now if the petrol cycle had changed as they are a learning system you could find the LPG was slightly out due to the petrol adjusting. If that makes sense [img]http://www.fuelly.com/driver/rob2529/range-rover[img/] 04, 4.4V8, Vogue Oslo Blue with LPG. "You can sleep in your car, BUT you can't race your house!!!!" If something can't be fixed with a hammer....... You have yourself an electrical fault! |
14th May 2012 8:34pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
+1 What he said Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
15th May 2012 11:41am |
OK, I got my new OBD2 to work after some port configuration trouble.
15th May 2012 10:15pm |
Tomorrow I shall attempt to remove the EVAP Purge Valve and see if it is working properly.
16th May 2012 4:53pm |
Just because no fault is shown for the air mass meter it doesn't always mean it's not knackered. Beg or borrow one to try if your other route fails and if you need a new one make sure it's OEM.
16th May 2012 5:42pm |
With the engine running look at the live values of the air flow and inlet temp.
17th May 2012 7:16am |
Latest update:
18th May 2012 10:57am |
Latest update:
21st May 2012 11:47am |
