![]() | Home > Technical (L322) > Driver seat and steering column problem |
Cannot find anything relating to your seat is it possibe that you have accidentally unplugged the connector under the seat.............
saxrom Member Since: 13 Dec 2008 Location: Grays Essex Posts: 23 ![]() ![]() ![]() |
Cheers Mick I have looked under the seat can't see any loose connections it's strange that the seat and steering adjust pack up together it's an intermittent fault but lately they have stopped working full stop. |
Do your mirrors work .......... ====================================
Yea they work ok |
Try this Self Test .......
Just tried the test nothing happened |
Only other thing i can think of is the ECU ........ ====================================
Ouch cheers Mick one thing do you know if they both run off the same fuse and if so where it is located. |
Found this regarding seat faults.........
will check to see where fuse is not sure if it's in the fuse box in the boot or in fuse box in the glove box ====================================
Cheers for your help Mick |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
not on mine it doesn't. Mine moves the seat all the time and has done so since it was new. The only thing mine does is I have to keep my fingers on the preset buttons if using the memory and the g/b is in drive. If Park is selected I only have to hit the memory button once and the seats return automatically to their saved settings. seems to be quite a few variations on the theme... |
Still looking not had a chance yet Saxrom ......... or if anyone else knows would be helpfull ====================================
