Home > Technical (L322) > Driver seat and steering column problem |
Cannot find anything relating to your seat is it possibe that you have accidentally unplugged the connector under the seat.............
1st Feb 2010 10:44am |
saxrom Member Since: 13 Dec 2008 Location: Grays Essex Posts: 23 |
Cheers Mick I have looked under the seat can't see any loose connections it's strange that the seat and steering adjust pack up together it's an intermittent fault but lately they have stopped working full stop. |
1st Feb 2010 3:19pm |
Do your mirrors work .......... ====================================
1st Feb 2010 3:29pm |
Yea they work ok |
1st Feb 2010 3:37pm |
Try this Self Test .......
1st Feb 2010 3:41pm |
Just tried the test nothing happened |
1st Feb 2010 3:49pm |
Only other thing i can think of is the ECU ........ ====================================
1st Feb 2010 3:56pm |
Ouch cheers Mick one thing do you know if they both run off the same fuse and if so where it is located. |
1st Feb 2010 4:01pm |
1st Feb 2010 4:10pm |
Found this regarding seat faults.........
1st Feb 2010 4:13pm |
will check to see where fuse is not sure if it's in the fuse box in the boot or in fuse box in the glove box ====================================
1st Feb 2010 4:16pm |
Cheers for your help Mick |
1st Feb 2010 4:28pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
not on mine it doesn't. Mine moves the seat all the time and has done so since it was new. The only thing mine does is I have to keep my fingers on the preset buttons if using the memory and the g/b is in drive. If Park is selected I only have to hit the memory button once and the seats return automatically to their saved settings. seems to be quite a few variations on the theme... |
1st Feb 2010 4:34pm |
Still looking not had a chance yet Saxrom ......... or if anyone else knows would be helpfull ====================================
1st Feb 2010 6:38pm |
