![]() | Home > Technical (L322) > Indicators come on as brake lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
could be a short but for both to do that its very weird..
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Obvious question sorry, but you have not changed a bulb or touched any connector have you? Previously..
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
earth fault? Mine was a blue one! |
just a thought, what happens if you have the hazards on and then brake? ... - .- -.
Another for an earth fault |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
3rd for an earth fault.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
4th for earth fault! When I was chasing a slightly different issue with my indicators I checked, cleaned and checked again all the earth points I could find. Turned out that one of my number plate bulb holders was slightly touching the chassis hence my weird light glitches. Bent it back and been fine since? Reformed |
Hoveronly Member Since: 08 Apr 2012 Location: Salisbury Posts: 39 ![]() ![]() ![]() |
Thanks for the input guys, does seem like an earth issue. Checked all connections, fuses, had a wiggle at all and sundry and its working normally again. Could have been the damp I guess as it has poured non stop here for days. |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
I had the sme problem a couple of years ago with a Honda civic. Same fault, especially when the weather was damp. Thhe indicators came on under braking. Had it, in an out of the garage numerout times. To cut a long story short, the mechanic spliced a new earth wire into each of the light clusters at the back and ran them to a suitable earth point (possibly chassis, but cannot rrcall) and this solved the intermittent problem. MY2010 TDV8 Vogue Ipanema Sand
