Home > Technical (L322) > Heater
gerymor
Heater
Can anyone tell me how to prevent the heater blower working when I just popped to the car to get something out, not going anywhere. I seems to do it every time and goes on for ages. It will not turn off, even when I relock the car,light on blower dial is lit. Have I got something set wrong?
It's a 3/12 Vogue SE, going in for 1st service in a week or so, they mentioned FBH software but I don't think that's the same issue, is it?
Thanks
Post #121509 12th May 2012 7:01pm
under warranty? dealer will sort it...
sorry miss-read the question, disregard this post.. Wink ... - .- -.
Post #121521 12th May 2012 7:59pm
A13X
2008 Range Rover Vogue SE TDV8 Stornoway Grey
I don't know if this is related but I get something similar. This morning for example, I started the car and reversed it back 2 feet, turned off engine and got back out. The FBH then continued to run for approx 3-5 mins. Normal?
Mines a 2008 VSE
Post #121527 12th May 2012 8:31pm
thats normal, yes... ... - .- -.
Post #121529 12th May 2012 8:39pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
It's a march 2012 Vogue SE and already going in for first service?
you do some serious miles. 15k in less than 3 months.
impressed. Bow down
Post #121567 13th May 2012 7:20am
gerymor
Oops! Sorry Rambles, it's a 3/11 NOT 3/12. Only just got it, was overdue service then! Anyway, don't think there is a fault with the blower, just don't know how to switch it off!
Post #121592 13th May 2012 11:47am
Rambles
if you've just got it, congratulations !
during the first service, they should check whether all the new FBH software was installed, the new AGM battery, and the level battery management unit.
Post #121600 13th May 2012 1:49pm
