Home > Technical (L322) > Not FFRR related, but need help...
Andy
Took the Golf in for an MOT last week and it failed on a leaky rear brake caliper. I traced the fault to a corroded sealing washer on the brake flexi hose (where it attaches to the caliper), so I replaced it. I then bled the brakes and the bleed nipple wouldn't tighten up. On closer inspection, it's stripped the thread in the hole Evil or Very Mad That's the problem when you bring a steel nipple together with an alloy caliper.
So, I was wondering- can this be heli-coiled or retapped with a larger brake bleed nipple? I need to get it done this week so if anyone can advise, I'd be most grateful. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #12076 31st Jan 2010 4:45pm
I don't know how to fix it Noddy but just make sure its done properly, Brakes are very important! Shocked Discovery 4 HSE
Post #12096 31st Jan 2010 7:19pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi Noddy, I've got racing brakes/callipers on my other car, the callipers being 19 yrs old now. My engineer stripped & rebuild them and as part of that exercise he had to heli-coil a couple of the more worn nipples and it worked fine. (He couldn't fit oversized nipples by rethreading the existing holes as they are too close to the edge of the callipers and would have risked the alloy fracturing but you may be able to do this).
Steve Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #12128 1st Feb 2010 12:34am
Andy
Cheers. I will make some enquiries into that today. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #12131 1st Feb 2010 8:03am
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Its probably easier to ring a scrapper and see if they have a used caliper in stock. Must be a common part to be saved and way less hassle. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #12132 1st Feb 2010 8:11am
Vogue
could check ebay for anyone breaking the right model golf
Post #12136 1st Feb 2010 10:43am
Andy
I've done all of the above- I would use eBay but I need it by Wednesday. I've just dropped it off at an engineering shop (mate of a mate) who said he should be able to do something with it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #12153 1st Feb 2010 4:25pm
Andy
UPDATE
I took the caliper to a hydraulic engineer. He worked his magic on it by drilling out the hole, re-tapping it, inserting a threaded bush, and then threading the centre of the bush. Works a treat! He reckons the seals will blow before the nipple gives up. Thumbs Up 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #12331 3rd Feb 2010 3:22pm
