![]() | Home > Technical (L322) > water logged |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Isnt it due to a leaking pump, Sure ive read that somewhere.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi, yes i have read this as well, its usually looks brownish.. V8 facelift Range Rover Autobiography 22" wheels.
ENVOY Member Since: 25 Mar 2007 Location: up a track in the middle of nowhere Posts: 239 ![]() ![]() ![]() |
What pump are you refering to?
hi, no the air suspension pump/compressor...its in your boot.
what about you rear wash, does it work, V8 facelift Range Rover Autobiography 22" wheels.
Yep rear wash wipe is fine having just had a new rear motor fitted.
hi, the air compressor can chuck out water but it wont be clear, i would get the spare wheel out,clean up all the water, check down the left and right sides to see if there is any there, if it is only in the spare wheel well then good...remove all you can, close the tail gate and with a hose run water all over the tail gate, you will be able to see from the rear seat if any is coming in...it may be the tail gate seal...check all around the top part of the seal as they may of disturbed some thing when they done the repair, keep that hose going for a while as it may only be a drip your looking for...
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
There's a Land Rover Technical Bulletin that covers water ingress into the boot. Might be worth a call to the dealer to ask about it.
Craig Mc Member Since: 30 Dec 2009 Location: WIGAN Posts: 17 ![]() ![]() |
I once owned a 55 reg 06 model and the boot use to fill up with water in the wheel well, i,m sure it was the welds in the floor panels that was at fault, LR dealer did sort it out under warranty they knew straight away what to do.
Craig, they probably drilled a hole in the floor! Discovery 4 HSE
