Home > Technical (L322) > CD Magazine Stuck ! |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 |
Folks,
27th Jan 2010 10:14am |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
remove fuse and then power back up is the normal way to get it out again,
27th Jan 2010 6:04pm |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 |
Our RR's must be twins - mine got stuck today as well!! Going to look into it now.
27th Jan 2010 10:19pm |
Thanks for the advice,
31st Jan 2010 6:20pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6362 |
Dead easy, bolt in/out and plug n play. (normally)
31st Jan 2010 7:21pm |
try the fuse trick again with thre door open, apply a little inward pressure to the cartridge when you press eject.
31st Jan 2010 7:41pm |
Thanks.... I'll try again tomorrow.
31st Jan 2010 9:21pm |
"True" as this problem could make you "Highly Strung" and with the right "Communication" someone might be able to throw you a "Lifeline" to save you from going "Round and Round" over this same fault but "To Cut a Long Story Short" hopefully someone will be able to help .........
31st Jan 2010 10:13pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1501 |
Mick-
31st Jan 2010 10:16pm |
Good effort for a Sunday night !
31st Jan 2010 10:58pm |
Sounds like Mick is a closet Spandau Ballet fan
1st Feb 2010 1:59am |
