![]() | Home > Technical (L322) > CD Magazine Stuck ! |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 ![]() ![]() |
Folks,
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
remove fuse and then power back up is the normal way to get it out again,
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
Our RR's must be twins |
Thanks for the advice,
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Dead easy, bolt in/out and plug n play. (normally)
try the fuse trick again with thre door open, apply a little inward pressure to the cartridge when you press eject.
Thanks.... I'll try again tomorrow.
"True" as this problem could make you "Highly Strung" and with the right "Communication" someone might be able to throw you a "Lifeline" to save you from going "Round and Round" over this same fault but "To Cut a Long Story Short" hopefully someone will be able to help ......... |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1519 ![]() ![]() |
Mick- |
Good effort for a Sunday night !
Sounds like Mick is a closet Spandau Ballet fan |
