Home > Maintenance & Mods (L322) > Rear washer blocked / not working. |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 |
When I try and wash my rear window I can hear the motor trying to squirt the washer fluid, but nothing comes out.
7th May 2012 10:40pm |
There is a non return valve in the rear system that goes faulty |
7th May 2012 10:42pm |
Yup - sorry - didn't search properly first - have found a load of advice now - will see if I can break it in the morning... Past (too many to list, but a few favs)...
7th May 2012 10:46pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
+1 Fist call is remove the cap and try it without the cap fitted... Craig |
8th May 2012 6:33am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2653 |
Did mine the other week, disconnect the plastic valve, get an airline attached to blow out the gunk from both the valve & the pipe feed to rear washer. Have a bucket handy when you disconnect the valve, it it's anything like mine, loads of muck came out . |
8th May 2012 8:38am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Good advice Craig and Stu.
8th May 2012 4:23pm |
8th May 2012 11:04pm |
