Home > Maintenance & Mods (L322) > Rear washer blocked / not working.
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
When I try and wash my rear window I can hear the motor trying to squirt the washer fluid, but nothing comes out.
The fronts are perfect.
Is there an obvious place where the feed splits from the washer fluid bottle? I'm guessing the most likely thing is that a pipe has been disconnected somewhere, but I don't know where to start looking...
TIA. Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #120782 7th May 2012 10:40pm
There is a non return valve in the rear system that goes faulty
Post #120783 7th May 2012 10:42pm
jfb1977
Yup - sorry - didn't search properly first - have found a load of advice now - will see if I can break it in the morning... Laughing Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #120784 7th May 2012 10:46pm
stu
if i were you, i would undo the three screws that hold the rear spoiler on, lift the cap off the wiper arm and clean out the nozzles and inside the cap, before you go doing anything else. there can be a load of crud in there stopping the water from coming out.
always start easy and work up. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120791 8th May 2012 4:40am
+1 Thumbs Up Fist call is remove the cap and try it without the cap fitted...
Craig Thumbs Up
Post #120794 8th May 2012 6:33am
Mr Tee
Did mine the other week, disconnect the plastic valve, get an airline attached to blow out the gunk from both the valve & the pipe feed to rear washer. Have a bucket handy when you disconnect the valve, it it's anything like mine, loads of muck came out .
Post #120813 8th May 2012 8:38am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Good advice Craig and Stu.
Took off the spoiler easily. Took off the cap easily. Washer worked fine and sprayed me completely all over!
Got a safety pin and cleared out the tiny metal nozzles in the cap and put it back. Spent ages faffing about to get the spray angles right but all well now.
One of the easier jobs I have done and apart from a wet jumper no damage done by me for a change.
Cheers! 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #120859 8th May 2012 4:23pm
Thumbs Up Thumbs Up
Craig Thumbs Up
Post #120938 8th May 2012 11:04pm
