![]() | Home > LPG > LPG - MPG |
Rykard Member Since: 16 Apr 2012 Location: Leicester Posts: 74 ![]() ![]() |
i am not an expert , but from reading a few posts on other forums it does seem that you get less actual mpg on lpg but this is offset by the cost being cheaper per litre. Something about the thermal content of lpg being lower than petrol and not giving as much 'bang' .. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1435 ![]() ![]() |
good conversion = 85% mpg on lpg compared to petrol - you will get less. I get about 15 to 16 mpg average. 17 to 19 on a run ( on lpg ) V8 or else ... |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 ![]() ![]() ![]() |
i thought that LPG gave about 2/3 of the mpg as petrol but and 1/2 the price, making it just a little cheaper to run |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
Im getting more from my SC than that!!! Return it to the agent for a setup... Craig ![]() |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Craig
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
68 litres of gas gets me 210 miles mixture of use which equates to 14mpg.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1037 ![]() ![]() |
I was getting from 220 plus on a tank, which was around 72 litres, on my S/C. Of course depends on type of driving, but that was with some short runs, mostly cross country, and some high speed on the motorway, without sparing the horses!
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
The calorific value of LPG is aprox 20% lower than petrol. Therefore you get aprox 20% less MPG. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Agree with MikeyJD mostly; you get a bit less bang for your buck. It was more noticeable on the old systems pre multipoint injection, I think. I can get near 20 on a run, light footed & mostly low 13s round town. I dont rely on the OBC -dont forget, thats just using values for petrol injection emulated by the LPG kit - fill - to fill is the true way to work it out.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3204 ![]() ![]() |
I work it out by cost per mile, using a tank to tank fill up. I get the equivalent of 28-30 MPG (using petrol at £1.40/ltr). I get around 240-250 miles per tank and fill up for c. £60.
I only have a 72 litre tank in the back ( 54litre fill ) and its too short a range for me ... does my head in sometimes. I can push it up to about 180 mile range at best.
Fisha-its worth considering upgrading the tank. They are not as expensive as you might think, and you will get money for your old tank. I got the biggest tank in mine, 102 litres, as I had your problem in the past. You need to fiddle about with the wheel well to make it fit but its worth it.
Costs me £60ish to fill and get 220-260 to a tank... That said, i only ever use LPG on a run i.e. if i get on the motorway i normally flick it on then... Craig ![]() |
Craig
