![]() | Home > LPG > LPG - MPG |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Interesting. How much fiddling, and does the boot floor sit completely flat? David |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
because of the nature of what the tank does [holds gas!!] , the best and safest place to buy one would be an authorised lpg dealer.. ... - .- -.
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
if you dont get a tank from a ALPG Installer it may invalidate your insurance
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Rads -
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
i get about 200 miles round town in mine but filling up all the time is a pain im going to upgrade my tank which is easy to do
Hoveronly Member Since: 08 Apr 2012 Location: Salisbury Posts: 39 ![]() ![]() ![]() |
Doesn't seem much point in having an LPG system if only used on the motorway. I cant tell when mine has switched itself on without looking. |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
I recently changed the spark plugs to NGK Iridium LPG plugs and the MPG seemed to fall from about 200 miles per tank to around 150-160! I've also had a front end 2010 conversion done recently, involving a new air filter, so I reckon the best thing is to get a decent remap which hopefully will restore some of the lost MPG. Local tuners charge £150 for a mobile but bespoke service ( not a chip swap). Worth a punt, as the short range is driving me mad! |
I was informed by a 'Chipping' company that they wouldn't remap an LPG converted car. Anyone any idea why that is? |
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
I get 13/14 mpg local and 17/18 mpg on a run to Anglesey on dual(65/70mph) and single(40/60mph) carriageway roads.
Tallsaj Member Since: 23 Aug 2013 Location: Birmingham Posts: 75 ![]() ![]() ![]() |
I just had my sc 55 plate range converted recently pain in the but to set up still not running good for some reason urban mpg I am only getting 120 miles max on 75 litres |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Something defo wrong there. A plug and drive SRC system should return 3 per litre not 1.6. What does it do to the gallon on petrol? Probably need restting on the gas base map.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I get between 200 and 220 miles out of 80 litres on a SC with prins. |
On petrol on £30 about 50 miles[/code] |
That's only about 10.5 per gallon on petrol. It suggests the car wants looking at before you do the gas.
