![]() | Home > LPG > LPG Conversion Questions.... |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I paid £1750 for my kit fully fitted. Not sure if any places would fit a second hand kit due to them certificating the work at the end. I've had no major issues with mine. Only one leaking hose and a slightly unsmooh change over from gas to petrol but was fixed with a software mod, all done free of charge.. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 ![]() ![]() ![]() |
Hi Rob,
Got mine done local to me. Andy Evans Autogas, can't recommend him enough, but quite a drive for you I think. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1021 ![]() |
As you say, it's all down to quality of installation. Also factor in convenience or otherwise of filling stations. I think probably the ideal is if you can get an LPG tank at your home. Not sure how much it costs, but it would get the gas cheaper, and would certainly be handy! Though I've never spoken to anybody who's done it, so don't know how practical it is.
Thanks for your replies
Just read that you can't take a LPG vehicle through the channel tunnel!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35501 ![]() ![]() |
been mentioned here before but its good to inform everyone. ... - .- -.
I find the No LPg rule on Eurostar interesting. I have taken (empty) LPG tanks for a balloon over in the past. Why can't you take a car with empty LPG tank and then fill up on the other side?
From what I know the rule is to do with safety. Our standards are very high here and would guess most systems are certified and safe, it's coming the other way the problem stems. There are alot of DIY systems avalible in Europe that they prob don't think are safe. I'm sure gas bottles have a standard across all of Europe so they will obviously be safe(er) [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Was in a filling station the other day and a Polish car came in and filled up with LPG... After filling and paying he returned to his old Passat Estate and opened his boot to get something out and i could not believe my eyes to see two butane type bottles lying down in the boot with rubber hoses to his LPG system! No straps at all! Just rolling around the boot! Mental!!!
Skinnyrunt23 Member Since: 20 May 2012 Location: Leeds Posts: 14 ![]() |
what happens with your spare wheel ? |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
You replace it with one (or two) of these....
I had a problem with a newish hose (less than 1 year old) on an installation done by an experienced and certified LPG station in the Netherlands and I still ended up parking my car (not the FFRR !!) at an abandoned airfield close to my house. Luckily it was only the 60 liter tank that had to vent off (non return / 80% level valve got stuck open), still it took 4 days. Both 120 liter tanks were still full !!! It should be noted that the 60 liter tank was older (say 5 or 6 years) as it came with the car. The filling hoses and bigger tanks (and the new converter) were installed less than a year earlier.
