Home > Technical (L322) > SAT NAV - Time to Destination
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Has anybody had this issue which has cropped up recently.
On using the SAT NAV for guidance , the time to destination is way out.
The mileage to distance works fine but for some reason doing any type of journey seems to give me an ETA of 10pm ish!
Help? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #12009 30th Jan 2010 6:34pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Is thats using the sat-nav or using it simply to show your current position? TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #12029 31st Jan 2010 9:31am
Vogue Owner
When using the Satnav to plan a route - this is the only way i think that it shows ETA CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #12033 31st Jan 2010 9:43am
Real RR
Yes, I've had similar. ETA seems to be about 10 hours out on occasion. Fiddling with the clock fixes it for a while but I don't know why.
I've pretty much given up on the Sat Nav as it's one of the worst systems I've used. Any handheld is better.
Post #12044 31st Jan 2010 11:20am
ukrangie
I have seen it be a little off by a magnitude of tens of minutes rather than hours.
Post #12045 31st Jan 2010 11:48am
Have you checked your Route>Preferences ??
Perhaps it think its going to take Toll Roads and is way off due to that? Discovery 4 HSE
Post #12047 31st Jan 2010 11:54am
Vogue Owner
IT WORKS!
Yep RealRR your correct, I went to the setting to change the time and the analogue clock suddenly zipped round the match the digital time (which was way out?)
Seems like the analogue? and digital clock had fallen out. Once the digital clock was reset to the correct time , the analogue syncronised to it and the SATNAT eta works fine.
Seems like some of the other settings had reset themselves like the audio settings too?
Perhaps a system blip or reset? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #12078 31st Jan 2010 3:58pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
When you service the car sometimes that happens.
There's something with both clocks that doesn't really work well. The internal clock and the analogue clock.
Out of service I usually have the instrument clock at one time and the anaogue at another, with the consequent nav system confusion.
Today I even had a stranger one. Started the route and had an arrival time of 13:55. Stoped for gas and suddendly after restarting the car it changed to 0:55. Very Happy Very Happy
The systems reset on startup after the gas messed it all up....
On the next car start, after lunch, everything worked fine, go figure....
My advice is, don't bother. Just understand the car, and, it's sometimes own willpower. Thumbs Up
Post #12127 31st Jan 2010 11:26pm
