Home > Maintenance & Mods (L322) > Best way of carrying 5 bikes 2006 VSE
Goatboy1972
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
As the title really. We are going camping in June with the kids and were wondering the best to carry two adult and three kids bikes. I have had a look at the rear mounted bike racks but don't want to end up with my tailgate scratched to hell.
Anybody have any suggestions as to my best option? Don't know if this is relevant but probably I will use for a week camping and then remove and then 6months later might do the same. So I will be fully removing any mountings in the interim.
Many thanks, Bruce
Post #120067 3rd May 2012 10:49am
You might be best off putting 2/3 on the roof, then hang the other two off the back. Get a bike rack that fits onto/over the towbar ball. You might need to get a "proper" towbar hitch where you bolt the ball on, and not use the default detachable swan neck type. .
Post #120073 3rd May 2012 11:01am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Towbar mounted rack with a number plate + lights. Cover the bikes using a large plastic sheet, some bungee cords and some foam pipe lagging. Done this many times in many cars and it keeps the bikes from getting covered in road crud too. If the kids bikes are small enough just take the wheels off and they should fit in the boot. Smile
Post #120074 3rd May 2012 11:07am
Hire/purchase cheap bikes when you get where your going... Maybe not as daft as it sounds! by the time you have purchased a towbar, a towbar bike rack, a roofbar system, mounts locks and god knows what else...
�20/30 per week to hire sometimes works out better if they will also deliver/collect afterwards...
Craig Surprised
Post #120075 3rd May 2012 11:09am
TheAllSeeingPie
Depends how much your bikes are worth? I wouldn't want to use a hire bike instead of one of my bikes. It'd be like hiring a van for the holiday instead of taking the RR. Cool
Post #120078 3rd May 2012 11:13am
as the 'bike' season is nearly upon us i'll move this the the appropriate section.. ... - .- -.
Post #120088 3rd May 2012 11:31am
Yes but if i wanted to move a large item ide hire a van for the day rather than risk wrecking my FF moving it! Same applies here...
Craig Whistle
Post #120095 3rd May 2012 11:43am
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Re: Best way of carrying 5 bikes 2006 VSE
Many thanks, Bruce
...... in a VAN.... Shocked
Post #120112 3rd May 2012 12:41pm
A1GSS
I use a towbar mounted bike rack which has the lights and number plate built in. Plenty of variants available. Mine takes four adult bikes. Really good.
Thule do several models that can take 5 bikes. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #120116 3rd May 2012 12:53pm
Goatboy1972
Will my car have a detachable tow bar automatically and if so where would I find it. Also are the electrics prewired?
Post #120121 3rd May 2012 1:45pm
A1GSS
No, and no. You need four bits (armature; towball; electrics kit; and ECU). Dan at Duckworth (site sponsor) can sort you a price out. Graham
____
Post #120141 3rd May 2012 3:43pm
hang on graham, the previous owner might have had a towbar fitted ...... not an 'automatic' option granted..... ... - .- -.
Post #120144 3rd May 2012 3:45pm
A1GSS
Ah yes, fair point... Graham
____
Post #120147 3rd May 2012 4:22pm
Fitting a tow bar just to carry bikes is going to be a mighty expensive option !
Craig makes a very valid point unless they are very good bikes hiring some when you get there may work out cheaper.
Somewhat depends on the frame sizes & shapes too - I've got a set of Thule roof bars & bike carriers but that won't work for smaller kids bikes. I've also got a MaxxRaxx tow bar mounted carrier that will take 5 but they need cross bars.
Both solutions work well but you're probably looking in the order of �3-500 for a roof based system & �1000 if you need a tow bar fitted......
Post #120185 3rd May 2012 10:02pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I would recommend looking at the rear of the car which is the traditional location for a tow bar.... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #120197 3rd May 2012 10:50pm
