![]() | Home > Maintenance & Mods (L322) > Best way of carrying 5 bikes 2006 VSE |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
You might be best off putting 2/3 on the roof, then hang the other two off the back. Get a bike rack that fits onto/over the towbar ball. You might need to get a "proper" towbar hitch where you bolt the ball on, and not use the default detachable swan neck type. .
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Towbar mounted rack with a number plate + lights. Cover the bikes using a large plastic sheet, some bungee cords and some foam pipe lagging. Done this many times in many cars and it keeps the bikes from getting covered in road crud too. If the kids bikes are small enough just take the wheels off and they should fit in the boot. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Hire/purchase cheap bikes when you get where your going... Maybe not as daft as it sounds! by the time you have purchased a towbar, a towbar bike rack, a roofbar system, mounts locks and god knows what else...
Depends how much your bikes are worth? I wouldn't want to use a hire bike instead of one of my bikes. It'd be like hiring a van for the holiday instead of taking the RR. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
as the 'bike' season is nearly upon us i'll move this the the appropriate section.. ... - .- -.
Yes but if i wanted to move a large item ide hire a van for the day rather than risk wrecking my FF moving it! Same applies here... Craig ![]() |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 ![]() ![]() ![]() |
...... in a VAN.... ![]() |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I use a towbar mounted bike rack which has the lights and number plate built in. Plenty of variants available. Mine takes four adult bikes. Really good.
Goatboy1972 Member Since: 22 Sep 2011 Location: ESSEX Posts: 26 ![]() ![]() ![]() |
Will my car have a detachable tow bar automatically and if so where would I find it. Also are the electrics prewired? |
No, and no. You need four bits (armature; towball; electrics kit; and ECU). Dan at Duckworth (site sponsor) can sort you a price out. Graham
hang on graham, the previous owner might have had a towbar fitted ...... not an 'automatic' option granted..... ... - .- -.
Ah yes, fair point... Graham
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Fitting a tow bar just to carry bikes is going to be a mighty expensive option !
I would recommend looking at the rear of the car which is the traditional location for a tow bar.... Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
