Home > Maintenance & Mods (L322) > De-tango'ing headlights in MY07 S/C. |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 |
I'm finally picking up my 2007 S/C next week (have been toying with the idea for months). Very excited!
29th Apr 2012 5:19pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
Check out this thread from the RRS site
29th Apr 2012 7:02pm |
Hi Daveo - I probably didn't explain myself very well. I was basically looking of a way of removing the standard orange reflector in the headlights.
29th Apr 2012 7:56pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
well i totaly got the wrong end of the stick there i thought he was talking about some from of orange sticker on the front lens. now i am with it i can tell you that you will need to split the light and remove the chrome trims, i have one apart in my garage as i am doing a set of led halos so i can check in the morning.. V8 facelift Range Rover Autobiography 22" wheels.
29th Apr 2012 8:12pm |
ok, as luck would have it i had the trims on my bench
29th Apr 2012 8:34pm |
Perfect, so if I can get hold of a clear reflector it could be a straight swap.
29th Apr 2012 8:46pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
You need a heat gun to melt the glue....
29th Apr 2012 8:56pm |
i will be doing a how to tutorial shortly on fitting led halos it will show you how to get them apart, you need to get the light nice and hot, yes i do use a heat gun but i putt the light in front of the oven first to get the temp up, you need to melt the mastic around the lens and pry open slowly making sure you keep it hot.. major tip is to watch out for the mastic it can get messy and you don't want it over the inside.. V8 facelift Range Rover Autobiography 22" wheels.
29th Apr 2012 9:16pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16268 |
Did mine on my 2012 conversion...
29th Apr 2012 9:21pm |
Craig, that looks well, have you put a light behind it, did you have to split the unit as well... V8 facelift Range Rover Autobiography 22" wheels.
29th Apr 2012 9:40pm |
Like that Craig. Like that a lot.
29th Apr 2012 9:44pm |
Yes an orange LED trailer marker light and a red one in the rear lights... Cant split the 09> lights by the heat method unfortunately so had to cut it apart and plastic weld it back together Craig |
29th Apr 2012 10:02pm |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 |
could you not put leds in the side part that would look smart
4th May 2012 10:30pm |
Sorry fella i disagree... If Land Rover made them that way i dont think they would have sold many! In my opinion obviously... Craig |
4th May 2012 11:11pm |
