Home > Technical (L322) > L322 Brakes Jammed on! |
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 |
Hi Gen IIIer's
27th Apr 2012 12:10pm |
Thanks for the info.
28th Apr 2012 8:40am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1370 |
The ABS sensors on the front stick into the hub and are visible from the front when looking at the hub. The wire tracks up and round to the rear side of the strut, through a holder on the strut which also holds the brake pipe and then up against the inside of the wheel well where is connector is placed inside a black box thingie with a flap up lid.
28th Apr 2012 10:20am |
This is an amazingly detailed post just to help someone out.
28th Apr 2012 10:53am |
Deleted double post L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not
28th Apr 2012 10:59am |
That's the thing, having a bit of hardware to reset things can really help and gives you some confidence to try things that will generate an error. There are plenty of links on here with a search to some tools that can read and reset errors. They are a worthwhile investment. ( I ponied up for a faultmate years ago before the alternatives were as good as they are now )
28th Apr 2012 2:02pm |
I did a brake fluid flush on all for wheels.
29th Apr 2012 5:48am |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I'm not sure that it's relevant in this case, but your model year has a reputation for the calipers binding, but usually just on one wheel, a rear, and not throwing up any warnings.
29th Apr 2012 6:51am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Sounds to me like your brake servo has given up... Previously..
29th Apr 2012 7:47am |
Thanks
29th Apr 2012 10:02am |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
If the brake servo wasn't working the pedal would be a lot harder. No longer FF owner but still interested. Present car Jaguar XE
29th Apr 2012 10:38am |
Not saying completely dead, just faulty. If you are sure that you have bled the system properly, then the only reason for a soft pedal and long travel is the servo..
29th Apr 2012 11:04am |
OK, this sounds a lot like an issue I had with my old Merc E55. The bit about causes looks to have been covered extensively above and the bottom line there is to get a fault code reader/clearing unit.
29th Apr 2012 11:36am |
Thanks all, appreciate the time and effort in the replies.
30th Apr 2012 3:22am |
