Home > Technical (L322) > L322 Brakes Jammed on!
fisha
simple master cylinder test is to press down on the pedal fairly hard ( I try it with engine off ) . There should come a point where the pedal stops and equals the pressure of your foot.
If it slowly drifts down to the floor under even pressure from your foot then that can be an indicator of the master cylinder seals going on the master cylinder. V8 or else ...
Post #119743 1st May 2012 7:02am
