Home > Technical (L322) > Wheelnuts- changes to type according to MY?
paneldamage
Hi All!
Quick question- I have come by a lovely set of 2010 MY alloys and tyres which I want to fit to my 53 plate Vogue. Will I need different wheelnuts, and what is the difference between the nuts on the older cars and the later ones?
The search button gave me more questions than answers..... Thanks in advance
Post #119105 25th Apr 2012 11:43pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Yes you will need bigger nuts - lol. Actually they are just a couple of mm bigger in diameter. You can get a set for about £40 on eBay. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #119106 25th Apr 2012 11:47pm
The dimensions of the two different wheel nuts are obvious when you insert them onto the wheel (try this before mounting the wheel) New style nuts will not fit onto earlier wheels and old style nuts will be loose in the aperture of the new wheels.
The length from the washer to the end of the nut is 20mm on both types but the end where the socket fits is longer on the new type and will therefore stick out further.
The other difference between the two nuts are the depth of thread which each can take.
The old nut has a depth of 28mm and the new nut can accommodate 45mm
Finally beware of cheap copies, you really don't want to loose a wheel at 70mph Big Cry
Post #119107 26th Apr 2012 12:16am
paneldamage
Thanks for the quick response and comprehensive info. I will have look for a new set on the net. Cant see any problems, just type big shiny nuts into the search bar on google...
Seriously, thanks chaps.
Post #119117 26th Apr 2012 7:35am
Stan this ones needs to go in WIKI Smile
Post #119119 26th Apr 2012 8:26am
has been there for ages gary elliott prestige cars.. Wink ... - .- -.
Post #119126 26th Apr 2012 9:33am
OK great stuff STAN Thumbs Up
Post #119128 26th Apr 2012 9:37am
