Home > Technical (L322) > Steering wheel paddles
Page 2 of 3 <123>
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Umm Baben, is stonosam's car a 5.0 supercharged like yours by chance? Rolling Eyes I'm getting a sinking feeling that maybe a gearbox update for petrol vehicles will work but why would there be a gearbox update for the 3.6 TDV8 diesel when it never had paddle shift, it was only introduced on 11MY 4.4 diesels with the rotary gear knob and why would the dealer do a software update to a car with a different engine and probably gearbox too Shocked
Let's see what they have to say later this week and I can but hope Confused
Andy 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #118535 21st Apr 2012 7:21am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Yes, Stono is a 5.0 s/c. BUT, until the new models were released sometime around 2011, we had no idea there was gonna be a paddle shift either, so perhaps the diesel will work. Have you opened up the steering wheel to see whether the little socket exists that you need to plug the paddles into? If the hardware is right, perhaps there is hope for the software.
Plus, in Faultmate, the "Gear selector switches (steering wheel mounted)" option is available regardless of what engine type. Perhaps there is hope. Lets see what happens
Post #118552 21st Apr 2012 8:35am
Ajay(UK)
Yes the hardware is fine, paddles all wired up and illuminated Thumbs Up
Looks like I may be the "diesel guinea pig" then Whistle I'm always up for the challenge and it's a cheap and easily reversible upgrade if it's not possible Confused
I'm still not convinced it will be possible as I remember reading that paddle shift was introduced for 11MY together with the rotary dial for the gearsl but our friends "state side" still retained the "man stick" with paddle shift for a while as there was a delay in introducing the rotary switch on the 5.0 SC Sad
All speculation at this stage though, Baben does your chassis number end AA****** or BA****** Question
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Post #118569 21st Apr 2012 9:27am
johnson1
NB: Still no rotary shift for Supercharged models, including 12MY. The gearbox and stick shifter remains the existing 6 speed one which was updated when the 5.0V8SC was introduced.
Post #118576 21st Apr 2012 10:31am
Baben
Andy - mine is AA.....
Post #118582 21st Apr 2012 11:34am
Ajay(UK)
UPDATE:
First off I have now established that a main dealer cannot enable paddle shift as their system does not extend to include all the CCF options Big Cry This means anyone wishing to have working paddles on a 2010MY needs access to a faultmate or similar or deep pockets to buy one Shocked
As to whether a software update to the gearbox is needed or not for the paddles to operate when enabled I will never know as it "seems" mine somehow now has the latest software version installed Whistle
I just now need to find someone with a 2010 multi-vehicle faultmate licence that's a bit closer than South Africa Rolling with laughter
Post #119396 27th Apr 2012 8:29pm
Renegade2
Andy any update on the paddles? Have you managed to get them activated? Current 2010 Vogue SE, Stornoway Grey with Storm Leather,Deployable steps, Vision Pack
Gone Range Rover 2005 TD6 Vogue
Gone Range Rover P38 4.6 Vogue
Gone Range Rover P38 4.0 HSE
Post #121078 9th May 2012 10:25pm
Ajay(UK)
Sadly not yet - I am still looking for someone with a Multi-Vehicle Faultmate licence Sad
On recommendation I emailed someone a couple of weeks who apparently can help but they have yet to reply to my message Big Cry
At this point there is no need to "name and shame" as there may be a very valid reason. Will keep you informed of my developments.
Post #121088 10th May 2012 8:20am
Ajay(UK)
Ok so latest update Exclamation
It's fair to say a faultmate owner with the required multi-vehicle licence for 2010MY onwards in the UK is as rare as well.........(add your own chosen metaphor) Sad
Solution?.......Buy one yourself Whistle So I am now the proud owner of a faultmate extreme with the said MV licence which hopefully may come in handy for others Thumbs Up
Keen to activate the paddles myself I hooked up the kit and enabled the steering wheel gear select option in the CCF and
It doesn't work Big Cry
I have checked my transmission software and my car shows 'AD' as the last two digest and not the required 'AJ' so either my dealer didn't update the software or if they did 'AD' must be the latest they have for a 3.6 TDV8 engine. I have yet to check this out as it was done somewhat "under the radar". Whistle Maybe 'AJ' is only available or supported for use on 5.0 petrol engines as I first feared but I'm not giving up just yet Wink
Post #125424 8th Jun 2012 8:03pm
stonosam
Australia
Hi Andy,
You need to find a dealer who has access to an Autologic diagnostic system and they can download the latest software from the main Autologic site.
That is untlmately where I ended up when I had all but given up on my MY10 supercharged 5L and it worked.
Unfortunately I am in Oz otherwise I could have given you the name of the dealer that did it for me.
Best of luck.
Stonosam
Post #125435 9th Jun 2012 2:40am
Dte1
United Kingdom 2009 Range Rover Vogue TDV8 Causeway Grey
Hi all, new to all things Range Rover! Have fitted the paddles as Ajay has into a 3.6 TDVE 2010 vogue and of course they don't work. Spoke to Craig at cam tech this morning who has confirmed your fears about the software not giving the paddle function or at least it not working. Just wondered how you got on with your mission?.
Post #322672 15th Apr 2015 8:11am
Ajay(UK)
I'm still waiting to be able to flash the transmission software with my Faultmate Embarassed The BBS cogs of development & troubleshooting seem to have slowed more recently Big Cry It also appears that you have to flash the transmission with the 5.0 SC software and as this point no one can tell me what effect this may have on a TDV8 Shocked
I will be selling my car soon and so the faultmate will go too Rolling Eyes
Post #322675 15th Apr 2015 8:21am
mzplcg
Just worth noting, I have a 2010 5.0 S/C and I successfully retro-fitted the paddles. However the normal gearbox software for the 2010 5.0 doesn't work with paddles so I used a hybrid version from GAP (Site Sponsor) which has bits of the D4 software to enable the paddle function.
But, I recall the gearbox in the 5.0 is not the same as the 3.6. Same stick, still 6 gears etc but I believe it was updated for the extra power of the 5.0. I stand to be corrected here though.
Post #322684 15th Apr 2015 10:08am
you are correct Dom,
6HP26 for the 3.6 [200kw,640nm] and
6HP28 for the 5.0 [380kw,625nm] ... - .- -.
Post #322685 15th Apr 2015 10:13am
Dte1
Thanks for the reply Andy, dare I ask how much you may be asking for your faultmate?
Post #322695 15th Apr 2015 11:13am
Page 2 of 3 <123>
