Home > Technical (L322) > door trim/window speaker gap?
been playing in the car and noticed that there is a 5-6mm gap between the top of the door card/window switch panel and the trim piece/window surround with the speaker in it.
it is the same on both sides. Is this normal or should it be tight. If so i will have to try and disassemble the doors and get it to line up better. Cant see that the panels have been off for any reason and as its both sides..... Question There is nothing that can't be fixed with a hammer😜😜
Post #118525 20th Apr 2012 11:06pm
Should be a tight fit
Post #118526 20th Apr 2012 11:19pm
daveo
the trim has not been fitted right, remove it and hook it in at the top first, it should be flush with the window. V8 facelift Range Rover Autobiography 22" wheels.
Post #118527 20th Apr 2012 11:21pm
Are we takling door trim or window surround. Question
As far as i can see the card is located correctly as the bolt and screws have to locate, and it would need to go up i think the window trim/speaker surround needs to go downwards. Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #118528 20th Apr 2012 11:39pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Would u be able to post pictures.. Thumbs Up
Post #118530 21st Apr 2012 12:25am
got it to fit a bit better, needed some new trim clips.
however still doesnt line up properly. While i was in LR dealer i looked at the shiny new one they had.
Didnt line up exactly on that either Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #118585 21st Apr 2012 1:30pm
Caused by the same mechanic not taking care Whistle
Post #118594 21st Apr 2012 4:13pm
