![]() | Home > Off Topic - Other Cars > Jaguar XF |
Good idea Bellini …. you as well Martin ... |
Have you tried a reset on it? |
So how do i do that John ...
Amusingly that is the same issue that my 2010 RR had .... it's a dealer fix. They need to sort the window ECUs |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
I had the same prob on my 2008 xf, stratstone replaced both front controllers under warranty, you may be able to persuade them to do the same even if out of warranty if it has been the subject of a technical service bulletin. You can search here for info. http://www.mycarstats.com/reports/jaguar/xf/tsbs.aspx Hope this helps. Agueroooooooooo. 93-20 I swear you will never see anything like this ever again....watch it..drink it in. |
Mick, it needs a software update on the window ecu. Wifey's was the same from new. It's just too sensitive on the obstruction detection.
Double post |
Cheers Dom …. |
