Home > In Car Electronics (L322) > Removing the cd changer
lala
2003 Range Rover HSE Td6 Atacama Sand
Hi all, I bought the Intravee for the wires birthday and have now gotten round to fitting it but have fallen at the first fence Crying or Very sad How to remove the existing cd changer, do I really have to remove all the glovebox? One post on here says it slides out but I've tried and can't get it to budge.
Any help appreciated or anyone know of a competent fitter near Colchester?
Cheers
Simon
Post #118248 19th Apr 2012 10:03am
mjdronfield
There is some info here ;
http://www.roverupgrades.com/Range_Rover_MP3_Cd_Changer.html
If I see anything more useful, I'll post......
RAVE doesn't seem to have much in on that.......
Bit more here ;
Range Rover CD Changer Removal.
Parts required.
Torx-20 driver
Torx-25 driver
Screw driver
Open the Glove box and start removing Torx-20 screws. The latch is held on by 2 Torx-25 screws. Then pop out the glove box light and unplug
Remove the trim cover underneath the glove box and the 3 Torx-20 screws
Remove panel on the side next to the door.
This panel snaps into place. Picture shows the location of the ‘snaps’.
Remove the panel on the other side of the passenger foot well. One Torx 20 screw and a few ‘snaps’ hold this one in place.
Location of the ‘snaps; on passenger’s side panel
Panel removed.
Remove the panel on the other side of the glove box so that the glove box can drop out of the way. Be very careful not to force anything and go slowly.
Lower the glove box and make sure all wires are disconnected except the 2 wires going to CD changer.
Wiring to the CD changer has LOTS of slack. Pull the slack out from behind the CD Changer.
Remove the Torx 20 screws on either side of glove box to free CD changer tray.
Once the CD changer tray is free remove the 4 Torx 20 screws on both sides of the CD changer to free the CD changer from the bracket.
Disconnect plugs (carefully pull the small oddly shaped 3 pin plug and squeeze the sprung sides of the square 6 pin plug. See below. (The 3 pin plug is to the left, the view of the square 6 pin plug is partially blocked by the wires for the 3 pin plug.)
Installation is a reverse of removal! Make sure you test everything before putting everything back in place!
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #118269 19th Apr 2012 12:51pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I have the LR PDF guide too if it of any help.
It was my CD Changer that just pulled out, but from what I can remember, it was only very early cars that had this benefit.
Post #118290 19th Apr 2012 2:20pm
lala
YeeeeeeeeeHaaaaaaaaa I persevered and we now have a working iPod Very Happy
The only thing to disappoint me is that we seem to have the earlier head unit software,
Thanks for the help guys.
Post #118291 19th Apr 2012 2:29pm
p38arover
Australia
I want to pull mine out to install the PiBus media centre: http://pibus.info/index.html
It seems that website is no more:
Quote:
RoverUpgrades.com
This domain is for sale: $7,095
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #711857 15th Feb 2025 2:53am
mjdronfield
This thread is coming up to 13 years old, so I’m not massively surprised.
The text I posted up should still be valid.
Might be videos on the net now.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #711887 15th Feb 2025 1:22pm
mjdronfield
Will be like this or similar….
https://www.fullfatrr.com/gallery/albums/userpics/10584/cda.pdf
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #711888 15th Feb 2025 1:26pm
