![]() | Home > General > Preview: 0.5M Wading Depth, Pah I say! |
ENVOY Member Since: 25 Mar 2007 Location: up a track in the middle of nowhere Posts: 239 ![]() ![]() ![]() |
OOPS! Too deep?
TDV8 Stats: Min. Turning Radius 12.6 m Approach Angle 29-34 degrees Ramp Angle 25-30 degrees Departure Angle 24.2-26.6 degrees Min. Ground Clearance 225-275 mm Wading Depth 700 mm |
Revised air intake. ![]() |
Does this mean the air intake is through the higher bonnet vent rather than a side vent? |
No idea - what we need is someone with a facelift RR to go out and take a look! |
I will take a peek later.... |
Ever heard of this manual: [url]http://www.whichmanuals.com/Cars/Land-Rover/Range-Rover/Range-Rover-L322-Workshop-Manual-(02%25252B).html[/url] |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 826 ![]() ![]() ![]() |
I saw a 2010 RR Supercharged yesterday and among other things the air intakes (there are 2, one on each side) are exactly where the red arrow points, (in the shape of the depressed metal) behind a plastic grille. I bet there are precisely 20 cm between the old intake and the new ones...
