Home > General > Shark Fin / Antenna Removal - height reasons |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
In all probability no.
13th Apr 2012 9:37pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
The shark fin is for the GPS..? Just wondering..
13th Apr 2012 10:49pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
My access is 15mm below normal .... however once on the stops....it's on the stops? Land Rover Addict
13th Apr 2012 11:06pm |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 |
correct me if im wrong... but the fin is just a plastic gps antenna
14th Apr 2012 7:32am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7809 |
A bit extreme I know, but if I couldn't get the fin sorted to allow access, I'd be cutting bits out the garage floor near the door to make a drop, so it clears.
14th Apr 2012 8:15am |
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192 |
Thanks ... I understand there is a later model antenna which is lower so I am going to check the height with that.
14th Apr 2012 11:27am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
the later fin is lower then the first one...how much room do you have V8 facelift Range Rover Autobiography 22" wheels.
14th Apr 2012 5:02pm |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 |
You could always let the tyres down
14th Apr 2012 5:21pm |
The info that I can find suggests:
14th Apr 2012 6:26pm |
With my garage door open I have 1850 clearance! |
14th Apr 2012 7:23pm |
02-05....dont have any fins/antenna..... so you would be screwed either way with only 1850 clearence... |
14th Apr 2012 7:42pm |
Strangely ..... from a different forum ...
14th Apr 2012 7:49pm |
