Home > General > Shark Fin / Antenna Removal - height reasons
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I used to have a 2002 Range Rover Vogue which JUST fitted in my garage when in access mode.
I then moved to a RR Sport and then to the dark side with an X5 Sad
However I want to return to FFRR but the new models have the Shark Fin antenna which makes the height even in access mode just too high to get under my garage door.
I don't really want to have to replace my garage door ... so does anyone know of any options to remove the antenna and replace with something flush?
I am looking at a 2007 Vogue.
Post #117020 10th Apr 2012 11:14am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
In all probability no.
it must be very tight as the sharksfin is not that big... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #117534 13th Apr 2012 9:37pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
The shark fin is for the GPS..? Just wondering..
But the IID tool could lower ur access mode more for u, can someone confirm if access mode is adjustable or is it generally set at the lowest level the ffrr can go?
Post #117547 13th Apr 2012 10:49pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
My access is 15mm below normal .... however once on the stops....it's on the stops? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #117550 13th Apr 2012 11:06pm
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
correct me if im wrong... but the fin is just a plastic gps antenna
thats bolted to the roof
... so whats to stop you fabricating it.... I.E...... grind it down
and touch it up with a bit of spray paint.... Thumbs Up
Post #117559 14th Apr 2012 7:32am
mjdronfield
A bit extreme I know, but if I couldn't get the fin sorted to allow access, I'd be cutting bits out the garage floor near the door to make a drop, so it clears.
You could have a metal grate thing over it when the cars not going in and out.
I know its extreme, but I'd look at it.
You may well not want to hack your house about, and again, this may only work if its just got to clear the door......
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #117566 14th Apr 2012 8:15am
Stephen.Gazard
Thanks ... I understand there is a later model antenna which is lower so I am going to check the height with that.
Can't really hack the garage door but may have to replace!
Post #117582 14th Apr 2012 11:27am
daveo
the later fin is lower then the first one...how much room do you have Question V8 facelift Range Rover Autobiography 22" wheels.
Post #117616 14th Apr 2012 5:02pm
Paul J.
You could always let the tyres down Laughing
Paul
Post #117620 14th Apr 2012 5:21pm
Stephen.Gazard
The info that I can find suggests:
Height:
73.3 in (1,862 mm) (2002–2005)
74.9 in (1,902 mm) (2006–2009)
73.9 in (1,877 mm) (2010–present)
My 2003 did fit.
Looks like the 2010 model is 25mm lower I am guessing the difference is the shark fin?
Post #117626 14th Apr 2012 6:26pm
Stephen.Gazard
With my garage door open I have 1850 clearance!
Post #117629 14th Apr 2012 7:23pm
hoppy
Height:
My 2003 did fit.
02-05....dont have any fins/antenna..... so you would be screwed either way with only 1850 clearence... Big Cry
Post #117631 14th Apr 2012 7:42pm
Stephen.Gazard
Strangely ..... from a different forum ...
"Extract from my manual (2007 TDV8):
A Overall width 2 216 mm 87.2 in
Overall width (mirrors folded) 2 034 mm 80.1 in
B Overall height
- Access height 1 820 mm 71.7 in
- Motorway height 1 840 mm 72.4 in
- Standard height 1 865 mm 73.4 in
- Off-road height 1 913 mm 75.3 in "
Looks like I need to get the car up here on Monday to test for sure !
Post #117633 14th Apr 2012 7:49pm
