Home > For Sale & Wanted > wanted parts for l322 |
Have you tried ebay? I hear they deliver. |
24th Jan 2010 10:09am |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
tried ebay thanks, they dont have any bits at the right price -just want t oget the compressor and bluetooth sorted incase i sell the car ,the wheels are for my next car |
24th Jan 2010 11:09am |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
whats actually wrong with the compressor onto no6 Range Rover
25th Jan 2010 6:20pm |
the car says suspension fault eveytime i get in it or raise or lower it then goes away ,when lifting the car from access it takes a long time but still works,had it plugged in and the guy told me it said compressor brush core temp overheating?? not sure if its getting tired or if its blocked lines etc |
25th Jan 2010 9:41pm |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 |
dryer ? And a bit of Wabcotyl in the circuit.... XJC, RRV8, Series1 86 and 107% of real pleasure |
26th Jan 2010 1:53pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1506 |
Mine was similar, turn on engine and it works albeit slooooooooowwwwlllyy, move anywhere and get 'suspension fault, normal height only'
26th Jan 2010 2:10pm |
if its temp related why not replace the temp sensor in the pump im sure land rover did a software update for compressor temp , also while your there replace the pressure switch as both are a common faults.
26th Jan 2010 7:00pm |
