Home > For Sale & Wanted > wanted parts for l322
BrianC
hi im looking for a compressor for a 2005 car also bluetooth unit and a set of 22" overfinch wheels
i live in lanarkshire scotland so i hope someone near has these bits for sale
Post #11536 24th Jan 2010 8:42am
dan_uk_1984
Have you tried ebay? I hear they deliver.
Post #11542 24th Jan 2010 10:09am
BrianC
tried ebay thanks, they dont have any bits at the right price -just want t oget the compressor and bluetooth sorted incase i sell the car ,the wheels are for my next car
Post #11548 24th Jan 2010 11:09am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
whats actually wrong with the compressor onto no6 Range Rover
Everyone needs a hobby
Post #11637 25th Jan 2010 6:20pm
BrianC
the car says suspension fault eveytime i get in it or raise or lower it then goes away ,when lifting the car from access it takes a long time but still works,had it plugged in and the guy told me it said compressor brush core temp overheating?? not sure if its getting tired or if its blocked lines etc
Post #11652 25th Jan 2010 9:41pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
dryer ? And a bit of Wabcotyl in the circuit.... XJC, RRV8, Series1 86 and 107% of real pleasure
Post #11693 26th Jan 2010 1:53pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Mine was similar, turn on engine and it works albeit slooooooooowwwwlllyy, move anywhere and get 'suspension fault, normal height only'
They diagnosed it was a knackered compressor although when they came to fit it was a hose come off the collector.
Also another thing which can make the compressor seems lazy appears to be the exhaust filter (see link below), take off the turtle shell in the boot and have a look around.
Try: http://www.fullfatrr.com/forum/topic229.html?highlight=suspension
Good luck Thumbs Up
Post #11697 26th Jan 2010 2:10pm
speedymarktd6
if its temp related why not replace the temp sensor in the pump im sure land rover did a software update for compressor temp , also while your there replace the pressure switch as both are a common faults.
£200-£300 at the dealer give or take cheap as chips and no need to buy a new compreesor as you possibly will get the same faults Thumbs Up onto no6 Range Rover
Post #11768 26th Jan 2010 7:00pm
