Home > Technical (L322) > Tyre noise when turning?
Page 2 of 3 <123>
why would you be Censored ing me craig.....
Mr. Green ... - .- -.
Post #111141 6th Mar 2012 8:50am
Awkward Whistle Whistle Whistle
Craig Laughing
Post #111142 6th Mar 2012 8:54am
Laughing ...... Wink ... - .- -.
Post #111143 6th Mar 2012 8:57am
Anyhow... Back to the mans issues Stan! Laughing Laughing Laughing
Craig Whistle
Post #111144 6th Mar 2012 9:02am
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Morning all, been working abroad, sorry for the delay replying!
@Craig - checked the tyres and nothing obvious there. I spoke to my local indy repairer and he said that although the steering rack balljoint issue was quite common on Discos and RRSs (same thing!) it was less so on the FFRR. Anyway, he doesn't think it's a panic or dangerous so I'll get that sorted after the holiday. Island 4x4 do the parts for less than £20 a side - I presume it's a fairly straightforward swap (gaiter off, unscrew inner balljoint, replace, get the alignment done?)
Post #111682 8th Mar 2012 11:20am
simon1233
Well, that was close.
between Stan and Craig we were in danger of:
But happily Cappo has steered us right Whistle
Post #111725 8th Mar 2012 1:57pm
craigs fault.... Mr. Green ... - .- -.
Post #111729 8th Mar 2012 2:01pm
swirl80
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Did u get this sorted Cappo? I'm having the exact same issue (worse when turning right at around 15mph) and was looking for ideas before the dealer tries to bullshit tomorrow me that there's nothing wrong....
Post #116266 3rd Apr 2012 9:10pm
Noticed a similar thing on mine the other day whilst driving onto the dealers forecourt. Don't think it was anything serious. Going to check it out when it gets back. There is nothing that can't be fixed with a hammer😜😜
Post #116269 3rd Apr 2012 9:16pm
Cappo
Hi Swirl - no, nothing done, not least because the remains of my T-boned FFRR are currently spread all over the floor of a bodyshop!
Prior to that, I had asked around and checked the car. The only thing I could find was some very slight play in the inner track rod ends - apparently not uncommoin, and the parts to replace are readily available, but I don't know whether that will fix it. Anyway, after noticing the problem, I drove to the Alps for a week, spent the week driving up and down Alpine hairpins, and the car was fine (although could still hear the noise sometimes) - so it can't be anything too terminal!
Will be interested to hear what they think it is on your car!
Post #116289 4th Apr 2012 7:31am
fisha
Could simply be the centre diff trying to do its job.
It's meant to try and balance torque to the front and rear axles, based on their different rotational speeds. Going round a sharp bend will make the props hafts turn at quite different speeds and the diff may be fighting it. That fight may get transferred back to the tyres and cause. Bit of scrubbing.
It used to be a common problem on the older classic rr which had a limited slip type coupling. It could seize up a bit and on sharp bends and corners it could cause the inner wheels to scrubb a bit due to the diff not allowing different prop shaft speeds. V8 or else ...
Post #116298 4th Apr 2012 8:30am
swirl80
After having the car for 16 days the first time and 5 days the second and almost £1k of warranty work done they've still not fixed it even though they said it was when I went to pick it up - both times!!! Bushes, bearings and track control arms (rear I might add....?) all been changed. Going back in on 16th for them to hopefully sort this time. I've had other ppl mention the diff being the issue but they're not gonna look into that as an issue apparently. It's also getting worse by the day!
Can't understand why they ring me to say all is well and within 30secs of leaving the dealers I can hear the noise, do they not test the car after changing a part or fixing it these days??? Shocked
I've also noticed the steering wheel being slightly off and both times it's been in they've sorted it and within a few days it's back to being offset again, any ideas if it cud be related???
Post #120610 6th May 2012 9:35pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
If it's the diff working it would more whirry than squeaky- sorry not getting the onomatopoeia right!
Post #120621 6th May 2012 10:32pm
swirl80
It's defo not a squeaking noise, difficult to describe. Suppose it's like very very bad tyre roar is probably the best description I can give. I'm positive it's not the tyres, if it were then surely it'd happen going both left and right....? I can also feel a slight vibration under foot when this occurs, not sure if it's normal or part of it but I don't feel it when turning left or cornering right faster/slower than 15mph.
Anyone on here live near the bedlington area (Northumberland) that fancies meeting up to give their opinion?
Post #120638 7th May 2012 7:20am
swirl80
Quick update on this. I asked the dealer to swap the tyres as that was pretty much the only thing not tried and low n behold, the noise went.
I was gobsmacked as I didn't actually think that'd be the issue. The car is fitted with Accelera Iota's which seem to do a decent job even though I've read many bad reviews about them. They took them off and put some toyo proxes on so using same wheels and no noise.
So, at least I know it's nothing dangerous or major and I'm happy to put up with the noise until the tyre swear out and need replacing. Still don't understand why it's only at exactly 15mph and predominantly turning right with steering wheel turned at 180 degrees.....
Post #126513 16th Jun 2012 11:01pm
Page 2 of 3 <123>
