![]() | Home > Technical (L322) > Tyre noise when turning? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35622 ![]() ![]() |
why would you be |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Awkward |
Anyhow... Back to the mans issues Stan! |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Well, that was close.
But happily Cappo has steered us right ![]() |
craigs fault.... |
swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46 ![]() ![]() ![]() |
Did u get this sorted Cappo? I'm having the exact same issue (worse when turning right at around 15mph) and was looking for ideas before the dealer tries to bullshit tomorrow me that there's nothing wrong.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Noticed a similar thing on mine the other day whilst driving onto the dealers forecourt. Don't think it was anything serious. Going to check it out when it gets back. There is nothing that can't be fixed with a hammer😜😜
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Hi Swirl - no, nothing done, not least because the remains of my T-boned FFRR are currently spread all over the floor of a bodyshop!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1457 ![]() ![]() |
Could simply be the centre diff trying to do its job.
After having the car for 16 days the first time and 5 days the second and almost �1k of warranty work done they've still not fixed it even though they said it was when I went to pick it up - both times!!! Bushes, bearings and track control arms (rear I might add....?) all been changed. Going back in on 16th for them to hopefully sort this time. I've had other ppl mention the diff being the issue but they're not gonna look into that as an issue apparently. It's also getting worse by the day!
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
If it's the diff working it would more whirry than squeaky- sorry not getting the onomatopoeia right! |
It's defo not a squeaking noise, difficult to describe. Suppose it's like very very bad tyre roar is probably the best description I can give. I'm positive it's not the tyres, if it were then surely it'd happen going both left and right....? I can also feel a slight vibration under foot when this occurs, not sure if it's normal or part of it but I don't feel it when turning left or cornering right faster/slower than 15mph.
Quick update on this. I asked the dealer to swap the tyres as that was pretty much the only thing not tried and low n behold, the noise went.
