Home > Technical (L322) > Transfer box leak? |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I'd be interested in any responses for this, mine has the same issue. |
1st Apr 2012 9:26pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Mine leaked through an oil seal and was fixed under warranty. It's a big job as the gearbox needed to be removed, so be glad you have a warranty to pick up the bill.
1st Apr 2012 9:35pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
Mine has the same issue. Input shaft seal leaking on the transfer box. Under warranty so getting sorted after Easter (as will be in Switzerland for most of this week) |
mines out of warranty, anyone tell me if its a big job? |
1st Apr 2012 9:40pm |
Apparently it is more than 4 hours labour as the Landrover warranty needed to have one of their engineers inspect and approve before they could do the job under warranty |
1st Apr 2012 9:43pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8625 |
Ringing Dealer today.
2nd Apr 2012 6:21am |
Booked in for tomorrow. Pretty quick There is nothing that can't be fixed with a hammer😜😜
2nd Apr 2012 10:54am |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Its a Land Rover of course it leaks.
2nd Apr 2012 8:37pm |
Aparently it was leaking from the case seal, not either of the input/output seals.
3rd Apr 2012 3:58pm |
swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46 |
Interesting.....mine had same leak as mentioned in this thread, they first said it was oil spill from when service done but when picked it up they said it was oil seal which they'd replaced. However, it was only an hour or so between the first call and picking it up, I just presumed it was a five min jobby. Low and behold, I noticed a couple of weeks ago it was "wet" with oil again. I'm gearing up for a massive kick off session with newcastle when I'm there in the morning!!! |
3rd Apr 2012 9:34pm |
Waiting to see what they have actually done. Had a good look round the box before it went in and should be able to tell of its been out or not.
3rd Apr 2012 9:50pm |
have got it back.
4th Apr 2012 8:36pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I have the same symptoms. Did it solve the problem completely? |
24th Jan 2014 3:51pm |
