Home > Technical (L322) > Transfer box leak?
Transfer box leak?
Just been under the bus today (57 plate tdv8) and noticed that the transfer box looked shiny and wet (no it wasn't raining) there was a thin film of oil on it and a small drop on the bottom bolts. Looked round the seals and couldn't see where it was coming out. Looked like it was coming all the way from the top of the transfer box. Could it be breather related?
There was a slight trail of oil from top but only a thin film. As its under warranty I might pop it to the dealer and see how much fluid they can fit in. If it takes a lot then it's likely to have been leaking for a while. If it takes a little then probably breather and nothing to worry. Whaddya think guys.
Are the tfr boxes supposed to be tough or are they a bit of a weak point?
Any help? There is nothing that can't be fixed with a hammer😜😜
Post #115898 1st Apr 2012 8:39pm
T24RES
I'd be interested in any responses for this, mine has the same issue.
Post #115910 1st Apr 2012 9:26pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Mine leaked through an oil seal and was fixed under warranty. It's a big job as the gearbox needed to be removed, so be glad you have a warranty to pick up the bill.
Gone - Range Rover Supercharged 2006
Post #115911 1st Apr 2012 9:35pm
simon1233
Mine has the same issue. Input shaft seal leaking on the transfer box. Under warranty so getting sorted after Easter (as will be in Switzerland for most of this week) Thumbs Up
Post #115912 1st Apr 2012 9:35pm
T24RES
mines out of warranty, anyone tell me if its a big job?
Post #115914 1st Apr 2012 9:40pm
simon1233
Apparently it is more than 4 hours labour as the Landrover warranty needed to have one of their engineers inspect and approve before they could do the job under warranty
Post #115915 1st Apr 2012 9:43pm
Ringing Dealer today.
Wouldn't have expected a seal failure at 4 years old.
Should have been picked up by supplying dealer before it was sold. Another case of them leaving something so warranty would sort it and not leave them with the bill I think. Not supplied by my local dealer in derby so it's going to them for the work.
Might get them to check out the transmission, it has that ever so slight jerk between 1st an 2nd as well, but only under part/light throttle. Might need a software reflash. But I'm being quite picky, it's so slight that most people wouldn't notice it. I'm just a bit fussy like that. There is nothing that can't be fixed with a hammer😜😜
Post #115928 2nd Apr 2012 6:21am
Booked in for tomorrow. Pretty quick There is nothing that can't be fixed with a hammer😜😜
Post #115969 2nd Apr 2012 10:54am
ahebron
New Zealand
Its a Land Rover of course it leaks.
If it doesn't leak its out of oil:)
Adrian VW Amarok 2014 Highline auto
Post #116092 2nd Apr 2012 8:37pm
Aparently it was leaking from the case seal, not either of the input/output seals.
Box out, more silicone based sealant, box back in.
No bother, warranty approve the repair and should have it back tomorrow. There is nothing that can't be fixed with a hammer😜😜
Post #116220 3rd Apr 2012 3:58pm
swirl80
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Interesting.....mine had same leak as mentioned in this thread, they first said it was oil spill from when service done but when picked it up they said it was oil seal which they'd replaced. However, it was only an hour or so between the first call and picking it up, I just presumed it was a five min jobby.
Low and behold, I noticed a couple of weeks ago it was "wet" with oil again. I'm gearing up for a massive kick off session with Censored newcastle when I'm there in the morning!!!
Post #116275 3rd Apr 2012 9:34pm
Waiting to see what they have actually done. Had a good look round the box before it went in and should be able to tell of its been out or not.
I would think that it would need taking out to reseal the casing, well actually it would be stupid to try it on the car as any oil on the case would prevent the sealant working.
Impressed with LR derby so far. Good comms and got it in quick. There is nothing that can't be fixed with a hammer😜😜
Post #116277 3rd Apr 2012 9:50pm
have got it back.
Hoovered out, washed, and hopefully fixed. FOC to me but saw the bill to the warranty, close on £500 which is pretty much all labour as there were no parts involved bar a bit of silicone.
Looks like the box came out. There is nothing that can't be fixed with a hammer😜😜
Post #116435 4th Apr 2012 8:36pm
wealy
I have the same symptoms. Did it solve the problem completely?
Post #236843 24th Jan 2014 3:51pm
