Home > Technical (L322) > 4.4 TDV8: Decelerating Fuel Starvation/Stutter? |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2014 |
Exactly the same problem..told Stratsones about it when it went for 1st service and lo and behold couldn't find anything wrong with it. The real pain in the ass is that it is so frustratingly intermittent, if the car would just grind to a halt maybe a fix could be found. I suppose the only real bonus is that the stutter disappears with a prod on the throttle...still it shouldn't happen on a car that costs close to £80k!!!!! |
28th Mar 2012 3:45pm |
RFAA Member Since: 22 Nov 2011 Location: North Yorkshire Posts: 17 |
Thanks Wackyjim - as you say, annoying on such a prestigious car and I have to say the three 3.6's i have had were all fantastic. When the 4.4 works its simply amazing, but this blip worries the hell out of you! My dealer seems to be hiding it, but i suspect they have no idea! |
28th Mar 2012 3:51pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
Same here. Car is waiting to go back to the dealer for a couple of other things (FBH included) and was going to mention it. Thought I was imagining it so sort of pleased to find others in the same boat.
28th Mar 2012 6:08pm |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 |
Get exactly the same problem. Dealer 'cannot replicate.'
29th Mar 2012 8:24am |
As above, the last new gen diesel from LR i had that started to smoke decided that lunch was going to be based around the bottom end of the engine, and then proceeded to eat itself.... LR warranty loved that pig of a job
29th Mar 2012 9:41am |
Good (sort of!) to hear that others are having a similar problem and mine isn't simply a Friday afternoon car.
30th Mar 2012 2:21pm |
My car hasn't got to the point of seeming as if it is going to conk out. I just get a little hesitation that a passenger wouldn't notice. Not certain if I want it to get worse (then the stealer won't be able to say "nothing wrong sir") or stay the same.
30th Mar 2012 2:30pm |
just had "the answer" from the dealership when I explained to the service manager exactly what the problem was.
30th Mar 2012 3:40pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
When I read what you describe in the original post, what came to my mind is that the gearbox is holding onto a gear too long before letting go and either easing off the lock up or changing down to the next gear. You can feel that sort of thing happen on autoboxes when coming to a stop at junctions and things.
30th Mar 2012 4:51pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 800 |
RFAA
31st Mar 2012 12:08pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Definitely noticed something similar to this when slowing for junctions and so on - it feels almost like engine braking with a manual as it moves down the gears, and out-of-sorts compared to how smooth it usually is. More worryingly, on a couple of occasions it has seemed to get stuck between gears on light acceleration from low speeds - pulling away, the change up doesn't happen, there's a big jerk and then it sorts itself out. Does anyone know if there have been any gearbox software updates? |
31st Mar 2012 12:23pm |
westylester Member Since: 21 Feb 2012 Location: devon Posts: 18 |
my 2012 has same issue,first time it happened i had been cruising at around 70mph and then came to a hill and the car started to judder and would not change gear untill i used paddle shift all returned after a few minutes.Im sure if enough of us shout loud enough lr will sort it.
1st Apr 2012 6:44pm |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 |
Have to say, so far not experienced this on mine.
24th Apr 2012 4:25pm |
not had it happen as bad since,but nearly every day i get the car to stutter,its almost like it cant change gears quick enough and struggles to find the correct gear especially at roundabouts when you approach at speed like on a303,its most defo a software issue.
24th Apr 2012 5:41pm |
