Home > In Car Electronics (L322) > Removal of sub woofer..
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
My woofer is vibrating v badly and buzzing since i bought the car so i just turned it off,I am hoping it's just the cone or whatever u call it that is damaged, has anyone tried the powerful uk replacement? http://bit.ly/GUTajo
How hard is it to remove the woofer, as I have read some posts here and haven't had much joy finding out of its worth the hassle..I'll also have a look to see if its just a loose bolt..
Post #115141 27th Mar 2012 10:42pm
5IMON
Are you sure its the sub?
Do you have a rear parcel net attached ? If so remove it and try listening to a bassy* song and see if it still vibrates
Post #115143 28th Mar 2012 12:40am
I had "sub-woofer " buzzing until I looked closely and found an aerial connector/amplifier bolted right next to it on a single bolt bracket was resonating, with the loose end touching the steel body of the car creating the noise.
Bent the bolted bracket back so the connector thingy couldn't touch the car steelwork, problem solved. Smile
Post #115169 28th Mar 2012 8:10am
Lolo
No rear parcel net, I'll do some investigation later to confirm.. Thumbs Up
Post #115172 28th Mar 2012 8:18am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
My Sub kept undoing itself ... check the securing bolts and use a bit of locktite to avoid it reoccuring. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #115174 28th Mar 2012 8:25am
Re: Removal of sub woofer..
Lolo, the powerfuluk one is an OE part, i have fitted them to my customers cars to replace shot subwoofers and can confirm they are a 100% fit (as long as yours has one large sub not two small ones)
I replaced mine too (was not even blown!) but at that price, i knew it was just a matter of time before mine went... Sold my old one for £55 on the bay... Result i say!!!
Grab them before he runs out of stock if i were you...
Craig Thumbs Up
Post #115177 28th Mar 2012 8:30am
SteveMFr
Site Sponsor
Removing the sub is not too difficult. I had that panel off more than once - but it's been a while. The guy in this thread says you have to remove the c-pillar trim but I'm pretty sure I didn't. What I wrote up is in the thread.
http://www.rangerovers.net/forum/6-range-r...eaker.html
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #115182 28th Mar 2012 8:52am
Lolo
can't believe this was an easy fix.. First time ever.. All I needed to do was tighten a few bolts.. Thumbs Up
Post #115989 2nd Apr 2012 12:25pm
DMRR
I was right Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #115994 2nd Apr 2012 12:29pm
jaybear
France
Lolo , How many vibrating , buzzing things you have in your trunk .
Its looking like your are ......obsessed ???? Laughing Laughing Laughing Laughing Laughing Laughing Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #116014 2nd Apr 2012 2:34pm
