Home > Maintenance & Mods (L322) > After market reversing camera?
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Actually does the camera plug in directly at the back of the touch screen rather that into the tv module or anywhere in the rear of the car?
T
Post #113451 16th Mar 2012 8:45pm
daveo
yes they are proned to taking in water..in the plug on the back of the camera it will be a 2pin plus the coaxial, as you said you will need to solder new connectors on to the cable unless you get a second hand LR camera, they do come up on ebay. V8 facelift Range Rover Autobiography 22" wheels.
Post #113452 16th Mar 2012 8:50pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
twhincup wrote:
tanertimur was it 1) how cheap for the camera and interface and 2) easy fitting for a non-electrician?
Hello twhincup,
The camera was cheap from flebay and im quite supprised its still working to be honest, picture is of good quality aswell as day and night with its night vision led lights.
As to the gvif interface its not that differcult to install, the only issue i had was sourcing a live feed which i got from the rear fuse box. Range rover td6 54 reg touch screen
Post #115061 27th Mar 2012 4:38pm
tanertimur
daveo wrote:
the only gvif interface i have looked at are quite Pricey at around £150, what have you got Question
Yeah i think i payed something in them lines too for mine. Range rover td6 54 reg touch screen
Post #115062 27th Mar 2012 4:40pm
johnboyjws
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
we have manged to find some conversions from the range rover leads (gold bullet) to the yellow AV lead, and snipped the wires (red black) and used connectors to power up to the exsiting lead, but the picture is distorted?????? John Wood
Post #116380 4th Apr 2012 3:01pm
daveo
are you using a NTSC camera.. V8 facelift Range Rover Autobiography 22" wheels.
Post #116382 4th Apr 2012 3:07pm
johnboyjws
yes we are now, first one we had said it was ntsc but turns out its mis sold and its pal. got another camera and we seem to be working! now just to try and mount it and wire it up properly. watch this space . . . John Wood
Post #116399 4th Apr 2012 3:58pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
The micro coax is a bit of a chore have to go to rapid online and buy an SMB crimp tool and some crimps for rg174 or rg316 and re make the connector.
For the factory camera the coax runs down the right d pillar and along the right side of the car and plugs in to the touch screen with a FAKRA (keyed SMB)
I swapped mine for a 2010 with the yellow lines and have to dl the pics and do a write up.
The original 2006 camera is sheeyit. There is a poorly bonded seam which lets water in.
Post #116407 4th Apr 2012 5:14pm
johnboyjws
well after much head scratching today over why we couldnt get the new NTSC camera to work on the existing power leads, we finally figured it out. we had previously has the PAL version working but with a distorted picture. luckily we have CCTV cameras at the warehouse here, so we pinched a power supply off one and used it to test the camera. worked fine. turns out the PAL camera had blown the fuse in the rear fuse box. new one of them and the picture came up crystal clear!!!
we drilled out the pop rivet holding the old camera bracket on and double sided the new one in place to line it up, then drilled 2 small pilot holes and self tapped the camera in through the spoiler. all sorted Smile
camera now sits nicely in the same place, hardly noticable and comes on the instant you select reverse, grid gives you a good idea of 2 foot and 1 foot away and the bottom of the screen is pretty much in line with the bumper (with a few inches to spare as a saftey buffer)
If anyone needs an adaptor making up for the gold SMB to a YELLOW AV cable just give us a shout, can sort one out that is plug n play Smile
cheers
JWS John Wood
Post #116510 5th Apr 2012 12:50pm
martin sells the adapters [smb to phono]...
http://www.disco3.co.uk/shop/index.php?act...oductId=34 ... - .- -.
Post #116514 5th Apr 2012 12:58pm
johnboyjws
ah yeh similar to the one we made up, ours has a standard yello AV socket on it and plugs directly under the spoiler into the old camera socket, not the screen. John Wood
Post #116515 5th Apr 2012 1:01pm
Thumbs Up ... - .- -.
Post #116517 5th Apr 2012 1:04pm
steadyaway
Hi there, I'm new to this forum but I'm a member of another. This is my second rangy, the previous one being a 3.5 V8 classic a few years ago. I also had a V8 Disco 2 in between. I too an having issues with my reversing camera and would like to know if there are any issues with swapping it for a generic one. I plan to pick up the 12v power from the original camera supply and connect the video cable to the original one also, either by fitting a SMB connector to the video lead (awkward to say the least unless you know what you are doing) or by getting a patch lead from one of the members on here. My worry is that as the OE camera incorporates a PCB, will it cause any issues or malfunctions fitting one without. I would hate to Censored the screen or the infotainment system. Thanks in advance for any input.
Post #315483 28th Feb 2015 10:40pm
