Home > General > Advise on buying 2002 TD6? Wise move? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
hi miles never bothers me as long as its got full history and very few owners as it means its been used and not sat at the dealers being fixed
21st Jan 2010 5:56pm |
It takes a bit of following links and is geared to the V8 (US models), but this is ok:
21st Jan 2010 6:17pm |
Yeah a few members on here refer to that site |
21st Jan 2010 6:27pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I've got a 2002 TD6 Vogue, which I bought last Feb. It hasn't given me any problems. It had 83k on the clock when I bought it, which at the time was little off-putting, but it drives like new and puts a smile on my face every time I get into it. I wasn't going to keep it at the time, but having run around in it for nearly 12 months, my opinion has changed.
21st Jan 2010 8:05pm |
d3matt Member Since: 21 Jan 2010 Location: Oxfordshire Posts: 2 |
I've read about the diff problems. I've also seen that you can buy a diff coupling shaft for £120 which enables you to replace just the propshaft and coupling shaft and leave the differential in place.
21st Jan 2010 9:30pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 228 |
The fix is to motor the steering column as far forward is it will go, adjust the seat so you can reach it, then leave it alone. That's what I do and the column never needs to move. |
22nd Jan 2010 12:56am |
