![]() | Home > General > Advise on buying 2002 TD6? Wise move? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
hi miles never bothers me as long as its got full history and very few owners as it means its been used and not sat at the dealers being fixed |
It takes a bit of following links and is geared to the V8 (US models), but this is ok:
Yeah a few members on here refer to that site |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I've got a 2002 TD6 Vogue, which I bought last Feb. It hasn't given me any problems. It had 83k on the clock when I bought it, which at the time was little off-putting, but it drives like new and puts a smile on my face every time I get into it. I wasn't going to keep it at the time, but having run around in it for nearly 12 months, my opinion has changed.
d3matt Member Since: 21 Jan 2010 Location: Oxfordshire Posts: 2 ![]() ![]() |
I've read about the diff problems. I've also seen that you can buy a diff coupling shaft for £120 which enables you to replace just the propshaft and coupling shaft and leave the differential in place.
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 254 ![]() ![]() |
The fix is to motor the steering column as far forward is it will go, adjust the seat so you can reach it, then leave it alone. That's what I do and the column never needs to move. |
