Home > Technical (L322) > TD6 engine running rough below 2,000rpm
TerryTurbine
France 2004 Range Rover HSE Td6 Giverny Green
First time at this, so here goes. L322 TD6 2004. 96,000mls Engine has started to sound rough below 2,000rpm. actualy it sounds noisy, like a lot of other diesels. still pulls well above 2,000rpm. Any Ideas. Current Vehicles: 2004 RR Td6,) 97 Nissan Terrano 2 SE (Old Reliable) , 1989 Merc S 260SEL, 79 XJS V12 manual, 85 VW Sirocco GTS
Post #113043 14th Mar 2012 3:26pm
Sounds like you have a leaky injector causing diesel knock which may not affect the engine above 2k rpm as it requires the extra fuel Smile
Time to whip them off and get them flow/pattern tested Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113049 14th Mar 2012 4:26pm
daveo
have a check for a air leak maybe on the vacuum side V8 facelift Range Rover Autobiography 22" wheels.
Post #113051 14th Mar 2012 5:21pm
clogged air filter, start with that... ... - .- -.
Post #113059 14th Mar 2012 6:05pm
