Home > Technical (L322) > I want to buy a ride height module |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
Your only choice is an IID Tool... Search the wiki...
4th Mar 2012 1:54pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Sounds to me like you want to reduce the ride height by as much as possible, then go into access mode whenever you park. The former can be done with an IID tool, the latter needs to be done with the dealer diagnostics, fault mate is it? Range Rover-less at the moment - Pining! |
4th Mar 2012 7:00pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Couldn' he modify his height sensors brakets, à la Disco III ?
4th Mar 2012 7:05pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6709 |
From the IIDtool userguide :-
4th Mar 2012 7:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35128 |
thats the tool then....contact stevemfr simon... ... - .- -.
4th Mar 2012 10:35pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
You can do much the same using the RAC (All Comms) along with a tape measure and calculator when you redo the calibration.
5th Mar 2012 12:17am |
If you do not want to do any diagnostic work, then the EASControl is more than enough to do the job. It has the same programming ability for the EAS as the IIDTool and fault read/clear on the EAS (no other systems, tho). And the cost is about the same as many lowering links that Joe mentioned which allow a mechanical lowering of the RR. And you don't have to crawl under the vehicle or can change heights in about 2 mins from inside the vehicle.
5th Mar 2012 12:36am |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 |
I checked out the EASControl pricing is around 180 im wondering though , would 22mm drop on 20 inch style 11 rims look that different?
7th Mar 2012 12:35pm |
i think you need to go to the lowriders'r'us forum.... ... - .- -.
7th Mar 2012 1:08pm |
7th Mar 2012 1:26pm |
