Home > General > What's the best fuel normal or super unleaded ????? |
rayman Member Since: 25 Feb 2012 Location: teesside Posts: 3 |
hi every one i'm just after some info ..... what the best unleaded 95 octane or superunleaded ???
29th Feb 2012 9:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35166 |
the best is whatever you can afford...some have reported that super-unleaded has given them a few extra mpg but for the extra cost it cancels out..
29th Feb 2012 9:59am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
The best petrol is the cheapest you can buy without going out of your way to do so - otherwise you cancel out the couple of quid saved on a tankful! |
29th Feb 2012 10:02am |
thanks guys i have always ran with super but my wife puts in normal ( cheaper option ) but as ive just bought this last month i was just woundering as the x5 i had seemed to have some fault with the ecu over the mixing of fuels ??? if this is correct... it was the 4.4 v8 x5, i just wanted to check as i think the last owner just used normal and i didnt want to go through the same problems on this.
29th Feb 2012 10:09am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I have a liking for Shell V-Power.
29th Feb 2012 10:31am |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
Its all about the LPG |
29th Feb 2012 11:42am |
@fisha
29th Feb 2012 1:38pm |
Beware that super cheap supermarket fuel can be poor quality and sourced from cheapest seller including bottom of the tank rubbish....
29th Feb 2012 2:12pm |
Gaz:
29th Feb 2012 2:21pm |
You may well be right about the bottom of the tank but I am pretty sure that Shell, BP, Texaco etc and Asda/tesco/sainbury fuel are of a slightly differing quality when it comes out of the pump.
29th Feb 2012 2:33pm |
You may be correct - to a certain extent!
29th Feb 2012 2:35pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I agree with Simes 100%, only difference is the additives that are differenct between Shell, BP, tesco, etc
29th Feb 2012 2:37pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Diesel |
1st Mar 2012 6:16am |
