Home > General > £200 for new key?!!
gachoud
2007 Range Rover Vogue TDV8 Stornoway Grey
£200 for new key?!!
The key for my 2008 TDV8 seems to have given up remote locking and unlocking. My delaer said the battery cant be replaced and a new key is needed at a cost of £200 (cant find the spare!)...surely there has to be a cheaper solution! Can anyone help? Thx
Post #108577 22nd Feb 2012 9:40am
The dealer is probably correct.
I had a very similar issue on one of our other cars, a Mercedes E55. Thought I'd be clever and sourced a secondhand replacement off eBay for £38 and left key in ignition to reprogram itself. No joy. Repeatedly no joy.
Had to be a new key at over £200.
Compared to some of the other problems on a RR, a new key is a cheap and quick fix.
Hope I'm proved wrong, though. Si. <This is my name.
Post #108579 22nd Feb 2012 10:10am
THats about right retail Thumbs Up
Ask Dan he maybe cheaper....
Post #108583 22nd Feb 2012 10:57am
dan_uk_1984
Just ordered a spare for our Megané... £150 so running a Range Rover isn't that much dearer!
Post #108713 22nd Feb 2012 11:26pm
daveo
i take it its a flip key...
get one of these, http://www.ebay.co.uk/itm/Key-Shell-Case-C...500wt_1203
then take a blade to your remote and cut apart,its not that hard, after you have it open you can remove the circuit board and replace the batt,it will need to be soldered but again its not a hard job, total cost will be around £25.00 what do you have to lose, shame you only have the one key as i would of done it for you... V8 facelift Range Rover Autobiography 22" wheels.
Post #108717 23rd Feb 2012 12:24am
daveo
just had a thought, you sure its the key and not the central locking module, what is the fault in a bit more detail.. V8 facelift Range Rover Autobiography 22" wheels.
Post #108718 23rd Feb 2012 12:31am
gachoud
thank you for the offer, as you say if we could find the spare it would be the way to go! The central locking works if you use the blade in the lock so I guess its not the central locking module?
Post #108990 24th Feb 2012 10:43am
daveo
i was talking about the RF module that receives the key signal..did the dealer say it was the key for sure V8 facelift Range Rover Autobiography 22" wheels.
Post #109151 24th Feb 2012 4:49pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
daveo
Is it the same cost to convert a fully functional BMW style key to the flip key?. I have a 2007 MY but was unfortunate enough to get a "lets use the old stock first" old style set of keys.
I have 2 so would be keen to see about converting?
Post #109339 25th Feb 2012 2:04pm
gachoud
its going into the dealer next week so ill get them to check and revert, let u know what they say Thumbs Up
Post #110054 29th Feb 2012 10:54am
daveo
sorry carlos, run that pass me again,, you have what type key and you want to do what.. V8 facelift Range Rover Autobiography 22" wheels.
Post #110118 29th Feb 2012 5:02pm
Googsy
He has the old style key and wants to covert to the newer 08 flip style key. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #110120 29th Feb 2012 5:05pm
MRT07
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Gachoud
I had a very similar problem to you. Whereby the one key I had worked fine. The other one would not even flash with a red light once pressed & I got quoted £280 for a replacement from the dealers. Therefore I took both my keys to a Car Locksmith Specialist who reprogrammeed my key for £25 & presto both keys work like brand new.
Post #110125 29th Feb 2012 5:22pm
daveo
hi you would need to get your hands on a bmw diamond key and see if you can code it to open and close the doors, as its a late car i am not sure what rf module it has, but if the diamond key works then you can convert it V8 facelift Range Rover Autobiography 22" wheels.
Post #110134 29th Feb 2012 7:01pm
