![]() | Home > Wheels & Tyres > Tyre Wear front to back..? |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Front.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1492 ![]() ![]() |
My fronts wore faster but, thanks to Craptinental only on the corners! |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
My fronts wear quicker on the outer edge - could be a tracking problem though. No longer FF owner but still interested. Present car Jaguar XE
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
fronts, as mentioned due steering, cornering and braking. lowish wear at rears unless driven like a sports car. I find the RR lends itself to more gentle acceleration...and cornering and braking, etc.... '96 Volkswagen Polo 1.4CL - SOLD
Jcsh Member Since: 27 Jul 2011 Location: Poitiers Posts: 29 ![]() ![]() |
A range of answers! |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2014 ![]() ![]() ![]() |
Definitely the front...When I put my winter wheels on the summer ones (Pirelli M+S) had 4mm at the rear and the fronts nearly 2mm with edges almost bare!!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34982 ![]() ![]() |
all the front 'wears' here are from tyres that have a wheel alignment or tyre choice problem...my range and many others dont so the fronts wear down evenly but not as much as the rears.... |
^ Not so sure about that Stan I'm talking about a new car with the original wheels and tyres. I have always been paricular with pressures etc and got the tyrefitter to check alignment and tracking when doing the winter wheel changeover and he said they were spot on. Had similar issues with my Sport which had Conti's fitted and was told by the dealer to expect slightly quicker front wear and in particular rapid edge wear( which apparently is a design characteristic of the Conti's and they have released a statement explaining this) |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1265 ![]() ![]() |
Of the tyres I've had on mine, the fronts have worn down quicker than the rears when fitting 4 new tyres, especially on the shoulders of the fronts ( both inner and outer shoulders, so I dont think its tracking )
My comment was due to experience.
On mine the fronts were more worn than the rears but also the edges on the fronts were worn a bit more than the rest of the tires. I have had all 4 replaced last week (Nexen Roadian) so will not be able to give any updates for quite some time (I don't do a lot of km's here). Had alignment done of course.
Just as an update: I've found that my rears wear 2x as fast as the fronts. This on 275/55/19 - just ordered 2 new for the front.
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 184 ![]() ![]() ![]() |
Mine is wearing out the outer edges of both fronts (scorpion zeros on 20" wheels).
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Hard cornering in any car will accelerate front tyre wear.
