Home > Technical (L322) > Suspension fault again
Andy
Last year, I had a fault message: air susp. Inactive. The lights went out on the control knob as well. I took it to Colliers in Birmingham, who reset it for free. Their technician said he hadnt seen this particular fault before, which added to the confusion.
Anyway, it's happened again.
This time though, for some reason, the front suspension is higher than it should be. No quite full height mode but higher than normal.
The funny thing is, this fault only re-occurred when I'd reversed onto my drive, which slopes slightly towards the house.
I'm hoping Colliers will take pity and reset it again but I'm starting to think its something that will need looking at in the near future, rather than a software glitch.
In the meantime- how can I lower the front to an acceptable level? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #109500 26th Feb 2012 4:00pm
mzplcg
Knife the airbags Laughing Laughing
erm, more seriously, drop her to access height and reset to normal might fix it. You sure it's not a front height sensor though?
Post #109503 26th Feb 2012 4:10pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
My suspension sometimes acts up too. It does say suspension lowered when in fact it's not but none of the controls to adjust it work. What I do is, disconnect and reconnect battery. Turn ignition on, turn wheel fully left and fully right then see if ur suspension goes back to normal when u drive off..works for me..
Post #109505 26th Feb 2012 4:32pm
Andy
Cant drop the suspension- nothing happens when I twist the controller or press the button on the door 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #109536 26th Feb 2012 7:08pm
Lolo
Even after u disconnect reconnect battery?
Post #109538 26th Feb 2012 7:22pm
Andy
Yep. Disconnected it, left it for half an hour then reconnected. Turned steering from left to right but hasn't cleared it and still no LED's on the controller 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #109614 27th Feb 2012 11:33am
Vogue
I had something similar. The maindealer wiped the fault codes and all ok since
Post #109619 27th Feb 2012 12:43pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I would try a new battery if not relativly new already after that i would put a new complete compressor assembly in the boot as most faults stem from lack of pressure or faulty valves on compressor and then go from there as for what a dealer will charge for diagnostics and repair will cover a new compressor onto no6 Range Rover
Everyone needs a hobby
Post #109649 27th Feb 2012 3:02pm
SteveMFr
Site Sponsor
Or save yourself the money for a dealer visit and purchase a diagnostic tool for yourself. There are a couple of people here on the forum selling them... Censored
As you'll need the fault cleared this way or that I would definitely have the fault read before throwing money at the RR. Post the fault code and we'll see if we can help.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #109679 27th Feb 2012 4:41pm
fisha
+1 finds out the error and take it from there.
The eas is pretty good at resetting itself for minor errors but harder faults logged persist ... So find out what it Is.
The eas tools and diagnostics are worth it IMHO. V8 or else ...
Post #109725 27th Feb 2012 6:04pm
Andy
Who's selling the diagnostic stuff? I'd probably go down that route. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #109878 28th Feb 2012 10:17am
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
It is worth remembering that to do the wheel alignment thingy (lock to lock) it needs to be before you move away after starting engine.
As in - if you drive off with suspension working, then it goes wrong and you pull in and do lock to lock this will not work.
You need to pull over. Turn off engine. Remove key and wait until all lights have gone off on dash, gear selector etc. The restart the car, keep in P or N and then do lock to lock before the car has moved. That should bring it back to life.
It won't cure a problem though so best to get it looked at and fault codes read.
Post #109880 28th Feb 2012 10:35am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I have Steve MFr's IID Tool.
I got a code C132 Lost Communication with ride level control module which appears whenever i get 'suspension fault'
Good luck finding your codes and sorting the suspension out!
Post #109921 28th Feb 2012 2:09pm
SteveMFr
Site Sponsor
I hit the wrong smiley yesterday... Embarassed
Was supposed to be this Whistle as we have the IIDTool
http://gap-diagnostic.com/products/iidtool.html
And here our distributor
http://britpart.com/newsstory.asp?PageRef=10&NewsRef=69
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #109973 28th Feb 2012 8:49pm
Andy
Price? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #111070 5th Mar 2012 8:06pm
