Home > In Car Electronics (L322) > Digital TV Tuner Problem |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
When I disconnect my fibre optic from the digital tuner only one red light is on from the two white cables..my tuner wont work correctly either, u buy from eBay? |
26th Feb 2012 3:55pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Think of them as IN and OUT. The red light you see is the input. There will be no light visible on the other side as the light will come from within whatever unit to the connector. I suppose you could trace the light round from one unit to another. If there is no input light then the fault must be from the previous unit... If you see what I mean! Previously..
26th Feb 2012 4:12pm |
buildr Member Since: 26 Feb 2012 Location: edinburgh Posts: 5 |
Lolo:It is a unit from ebay.
26th Feb 2012 4:55pm |
Did u buy from a person called kenno..? Both myself and another person on this forum
26th Feb 2012 6:50pm |
Buildr.... Sounds like a classic fault with Nokia unit. Read my post http://www.fullfatrr.com/forum/post99656.html#99656 the bit about linking out the Nokia is the bit you need to read. Previously..
26th Feb 2012 7:55pm |
Thanks Contraband, i will look into that. What is the Nokia box, is it for the car kit that I dont use?Presume its not bluetooth?
27th Feb 2012 5:15pm |
Nokia unit is for the blutooth. Have you tried scanning the blutooth with your telephone to see if you can see the car? Previously..
27th Feb 2012 6:33pm |
Good call Contraband. It didnt work so problem lay with Nokia.
28th Feb 2012 6:06pm |
Glad you got it working. That's what the forum is all about. Previously..
28th Feb 2012 7:18pm |
