Home > Maintenance & Mods (L322) > Convert Fogs to DRLs ?
Page 1 of 3 123>
Don't find my fog lights any good in fog, so got thinking to use them as DRL's?
Would this confuse the Police?
How to get them to come on with ignition?
What bulb should I change to?
Stupid idea? .
Post #109291 25th Feb 2012 10:36am
Joe90, mine have been done since mid 09 and have had no problems from da fuzz or MOT's
Wire them to a five pin relay with a blocking diode between them...
Had a xenon kit in at first but found them too bright (like some buy racer cars) so reverted back to standard bulbs...
Craig Thumbs Up
Post #109293 25th Feb 2012 10:51am
done mine ages ago...drl switch brought of ebay, splice into the headlight wiring for live ignition and headlight feed..
live ignition switches the leds [in fogs] when you turn the engine on and headlight feed switches the drl's off when the headlights are switched on..
i've had no problems with the law or mot and even when going abroad ...
i tried the drl's in the high beam headlights and the high beams in the fogs but decide finally on the fogs..
Post #109299 25th Feb 2012 11:20am
the unit that i have ..
http://www.ebay.co.uk/itm/260798015020?ssP...1423.l2649
and a cheaper one ...
http://www.ebay.co.uk/itm/230727784057?ssP...1423.l2661
Post #109302 25th Feb 2012 11:24am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Anyone fancy a mod to their no led headlights to include the angel eyes DRL's..??
OR will they be naf or not possible to fit.?
Linky Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #109352 25th Feb 2012 4:21pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Comport u seen these
Post #109372 25th Feb 2012 7:05pm
comports
I did cliffy - not sure I really like them. I do like the look of the angel eyes and I believe the newer Full Fats have them already. Would love to do the front end conversion but not that rich..! Crying or Very sad Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #109380 25th Feb 2012 8:05pm
OK Stan, like the look of the kits. For that price, it's worth a go. What LED bulbs go into the fogs to replace the existing ones?
And do you disconnect from the normal fog light wiring altogether?
Photo how to would be nice Wink
Useful link from Stan's second ebay post http://www.genlabs.co.uk/support/documents/drlr2.pdf .
Post #109402 25th Feb 2012 11:44pm
simon1233
Comports, have a look at this thread from the RRS site
http://www.rrsport.co.uk/forum/topic23579.html
Could be an option if you're feeling brave/adventurous Thumbs Up
Post #109420 26th Feb 2012 8:20am
@joe..i put 18 smd's leds in , the 21/27 smd's are to large in diameter to go in the fog aperture but ok in the mains..
i cut the fog wiring and connected the wiring from the drl switch...i connected a 50ohm resister to the existing fog wiring to stop the dash errors, i also make sure i dont switch the front fogs on ...
i'll try and get round to doing a video and stick it on youtube..
Post #109436 26th Feb 2012 10:33am
@stan like this?:
http://www.ebay.co.uk/itm/H7-18-SMD-LED-DA...3cc0ec2a40 .
Post #109442 26th Feb 2012 10:52am
that's the ones joe but i didnt pay that much , it was a whgile ago and i think it was about £9 for the two..i brought a spare set as well cos sometimes you get dry joints on the base of them.
Post #109445 26th Feb 2012 11:07am
Could I just reconnect the "old" bulbs to one of these:
might serve as a useful under bonnet light with the right holder Wink
or where would I find the right type of resistor to fix to the wiring? .
Post #110982 5th Mar 2012 12:36pm
on one of my projects i did connect some blue lights mounted under the bonnet and that took the error away ....if you want to go the resister route then ebay has them, get the 50ohm ones... ... - .- -.
Post #110985 5th Mar 2012 1:00pm
mjdronfield
I think you can do stuff like this with Navcoder.
I know you can set the light control module to do all sorts inc upto 50% power to main beams as drl's........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #111002 5th Mar 2012 3:13pm
Page 1 of 3 123>
